Okay, I will try upping the voltage a little more. I am not sure about the Vdimm. Is that the same as the DDR SDRAM voltage, if so it is default at 2.6v, the Chipset is at 1.6v, and the AGP voltage is at 1.5v. I have AGP frequency set at 66mhz (default), CPU FSB/DRAM ratio=Auto, CPU Interface=Enabled (just did this). Don't know about all the other settings and have been hesitant to mess with them.
Thanks so much,
Dan
