- Dec 19, 2000
I have an Asus A7v133 motherboard and basically my problem is this: Prime95 will fail with a rounding error whenever a sound card is plugged into my board's PCI slot. I have two A7v133s and this happens on both of them. Furthermore it happens no matter what sound card I use (Sound Blaster Live! or Aureal Vortex2 SQ2500), no matter what PCI slot I put the card in, and no matter what speed I set my processor to run at.
If I set my processor to run at stock speed or below, it will still fail with a rounding error. However, if I just pull the sound card out, it will run Prime95 stable forever (unless I clock it up too high, but that is a different story entirely).
Has anyone else suffered from this problem and does anyone have any idea what might be causing this? Also, do you think this is just a problem with Prime95, or do you think my system is just totally unstable whenever I have a Sound Card plugged in to it (I kind of doubt/hope that is not the case). What else is a good stability test besides Prime95?
