hey all.. for some reason i decided to run prime95 to see how my OC was doing... not that i had, had any problems while running anything or crashes but just for kicks and to see how hot it got..
core0 runs fine on all 3 tests but core1 keeps crashing.. on the 2 big tests almost instantly while on the small one after test4 or so.. and i don't get it.. i've upped the voltage a bit to see if that got it kicking but nothing.. and i'm curious why...
the error is the got .5 when expected .4
temp on both seemed fine.. 54C max on both, ambient is 28... any other info you should need let me know and i'll add it.. if it's BIOS info there are a lot of things i have no clue about to be honest.
only voltages i touched were CPU and RAM.. most of the other ones aside from NB/SB i don't have a clue what they mean or are..
well any help is welcomed..
thanks in advance
thanks in advance
