- Apr 4, 2004
Hello Every1
Upgraded my motherboard recently from the Asus A7N8X-E to the DFI Lanparty Ultra B. Also upgraded my memory for the Mushkin PC3500 (BH-5).
Since the install ive been trying to push FSB up as much as i can with the CPC enabled. When i run prime95 with the torture blend test, it runs the first test (1024K) and passes it but when i used prime95 on my last setup it would start test 1 but it would break it down into 3 sub-tests and then pass Test1. But now it wont show the sub-tests from each test but would still pass on the tests. Ive had my computer runing for the last 24hours on prime95 and has only done 10 tests. On my last setup it would have done the whole cycle of tests and be done.
Any advice or hint is grateful
Thank you
Thank you
