Printer problem
afcbob
I just got my self a Epson SX215 printer scanner.
I plugged it into my computer running Vista with a usb and i can get print fine but it wont scan.
I plugged it in to my Sony Vaio laptop and it will print and scan.
So i no its not the scanner it must be my computer.
Computer spec:
P4 2.6 ghz
1.5gb ram
HDD1 80gb
HDD2 40gb
Theocnoob
Near Toronto Canada
go to epson see if theres any update for xp on your printer solfware
Rich
OR if you want to do something that will actually apply to you, as you're running vista :santa: make sure you have the latest service pack and any critical updates and make sure you installed all the correct drivers.
