Printer question
Talon101
Japan
Heres my situation, my printer is set as a network printer, and i think that side of the problem is set correctly. but it still says that the printer is offline. I was wondering on how to change the status to online, is there a option to do that? i checked the connection and thats fine, the printer is on, but the computer doesnt see it online. any suggestions?
Oswalden
nampa, idaho
what kind of printer is it. and do you know if the printer is turned on and offline or if the printer is truely online and the compuer it not reconizing it. Also what OS are you running and what is your setup for the network?
Talon101
Talon101
Japan
its a Canon BJC-3000, the printer is turned on but the computer isn't recognizing it. Im running win 2k pro, i just updated the driver for the printer, and now its (pc) recognizing that the printer is there (Status: Online) but it still doesn't print.
RED Hot Machine
Inactive Moderator
Have you installed the printer as a local printer on the machine that it is connected to or as a network printer ?
To use a printer which attached to a pc on a different pc on the network, you have to install it as a local printer first. Then share it so that other computers can see it.
Once you have done that you can then setup the printer from other machines as a network printer.
Good Luck
Andy
