- Dec 27, 2008
A 3600x will run significantly cooler than a 2600x because of the 7nm fabrication process used and perform better as well. Why would you not go with the newer technology?
And there are a lot of good, reasonably prieced options for socket 4 B450 chipset motherboards right now. But I would caution you about overclocking the "X" Ryzens. They are pretty much topped out from the factory at stock. There is not much to be gained by overclocking them since on all cores you will not likely be able to achieve turbo speeds and for only a small performance gain you may be sacrificing chip longevity. It is a different world than it used to be for overclocking. Those big gains are no more.
https://www.amazon.com/MSI-Performa...max&qid=1589740892&sprefix=msi,aps,215&sr=8-8
You also might want to wait for the B550 motherboards to debut, supposedly next month.
