Hi,
I hope I can get some help regarding failure to overclock my Q8300.
I had until a couple of weeks ago, Core 2 Duo [email protected] and just by increasing the FSB from 266 to 320 I managed to get it to 3.2Ghz, piece of cake.
I replaced that CPU a week ago with Core2Quad [email protected] Ghz
FSB is 333Mhz. So I just thought I increase it to 400Mhz, adjust the RAM which is DDR2-800 to run at 400Mhz and make sure PCI Express stays at 100 Mhz.
However even if I increase the FSB even by a bit to 350Mhz the PC won't boot, i.e. won't even finish POST.
All my voltages are set to auto except the CPU Vcore which was 1.1 in BIOS but CPU-Z shows 1.12 to 1.137?? I tried increasing that to 1.5 in the BIOS even, still can't finish POST.
My PC specs:
MB: MSI P31 Neo V2
RAM: 2x2GB DDR2-800
Cooler: Arctic Cooling Pro 7
I have the option on the mobo to adjust the FSB, FSB/RAM ratio, CPU Voltage, DRAM Voltage, NB Voltage, VTT FSB Voltage, SB Voltage, SB Core Power. They are all set to Auto except the CPU Vcore (which doesn't support Auto).
Any suggestions of what I might try?
Thx
My PC specs:
MB: MSI P31 Neo V2
RAM: 2x2GB DDR2-800
Thx
