Folks,
i just finished setting up my SMP system. ASUS A7M266-D with dual Athlon MP 2000+.
OS : Windows XP Pro
System works fine and see's both CPU's however when i try to run 3DMark2001SE which i just downloaded last night and installed. I get the following error when i try to start it -
3DMark2001 SE requires a processor with MMX instructions.
We recommend that you upgrade your computer or test your PC with an older version of 3DMark.
I looked in the error log it generated and it seems to be able to detect everything on my system except the CPU. Can't seem to recognize it.
Here's a snip from the log
Application info
Name 3DMark2001 SE
Build 300
Error log
MMX instruction set required.
System info available: yes
Project available: no
System info
System Info Version 2.2
Installation ID 0x00000000
OEM ID
CPU INFO
CENTRAL PROCESSING UNITS
Manufacturer
Family <unknown>
Internal Clock 0 Hz
Internal Clock Maximum 0 Hz
External Clock 0 Hz
Socket Designation
Type <unknown>
Upgrade <unknown>
Capabilities none
Version N/A
CPUID 0x00000000
After this it shows all the info for my DX, Vid card, RAM , HDD etc etc ..
I then downloaded 3DMark2000 and that seems to work fine but it doesn't use DX8.1.
Just wondering if anyone has run in to this problem?
OS : Windows XP Pro
Application info
Name 3DMark2001 SE
Build 300
Error log
System info
OEM ID
CPU INFO
Manufacturer
Family <unknown>
Internal Clock 0 Hz
External Clock 0 Hz
Socket Designation
Type <unknown>
Upgrade <unknown>
Capabilities none
Version N/A
CPUID 0x00000000
