problem shutting down in xp
Mystikal
I NEED TO CONTACT SILVERSINKSAM TO DISCUSS $80 I o
Rochester, NY
I have 2 identical systems and on one the comp the computer shuts down and turns off it off and on the other it shuts down and sits at the " it is now safe to turn off the computer" screen .
Is there a way to get the second machine to turn off?
Thanks.
David
Forums Super Moderator
Thanks.
Are they definately identical? Looks like one is ATX (turns itself off) and one is AT (doesn't :D).
If they are identical, looks like XP hasn't seen that one is ATX. You miught need to enable ACPI in the BIOS for the system to power on and off itself.
