Problem with ASUS and Leadtek
Ciberputa
La Coruña, Spain
Hi
I have just installed a motherboard ASUS with PIV 3,6, 1GB Kingston DDR400 (Asus recommended) and a Leadtek Winfast A250TD (Gf4 Ti4400). When I turn the system there is not video signal and monitor does not turn on.
Motherboard manual says that AGP video card should be 1.5v and I think that A250TD is 1.5v.
Do you know what is the problem?
Thanks.
Ciberputa said:
Hi
Thanks.
Your Ti4400 should be 1.5v. I know my 4200 is.
When you turn the system on:
- Do the fans spin up?
- Any beeps?
- Is the card, the RAM, and the CPU all seated properly?
Thx for your answer.
- No beeps.
- All the fans spin up
- It's supossed that everything is seated correctly, CPU only fit in 1 position and the same for memory.
May be the motherboard is damaged, I don't know but it's very frustrating. I'm going to reinstall everything from the beguinning and see...
- No beeps.
Yeah maybe try and rebuild it and make sure there is no dust or anything in the way. Also, if possible, try and test your Ti4400 and your RAM in another board?
Nothing changes, reinstalled everything and stil no video. It's strange that the motherboard does not beep when I turn it on.
