H
Howard
Guest
I just reformatted my hard drive and installed the above mentioned card. I've had other G'force cards in my system with never a problem. When I installed this card I started getting corruption even while installing windows. Thin green vertical lines that appeared on my screen. I proceeded with the install and figured once I installed the drivers the problem would disappear, however it didn't. After I installed the drivers off the CD my system would lock up a short time after my desktop appeared. All I had to do was just click on a couple of things then I'd be locked up. My system was "not" overclocked during install......any ideas?
PIII [email protected] w/alpha, Abit BE6 II Ver 1.0, 256MB mushkin Rev 2.0, Maxtor 7200, NEC Multisync M700
