Hi all,
First let me tell you what system I'm running
AMD Duron 650 @ 909 8.5X107
Asus A7V Motherboard
PC 133 RAM (oem low quality)
Vantec hs (w/delta fan noisy!!!)
CPU Voltage @ 1.75
idle temp around 42C
load temp around 46C
My problem is that I can get my cpu to run at over 900 mhz using an 8.5 multiplyer setting and an fsb of 107 or >. However when I switch to a 9.0 multiplyer setting using a fsb of 100 or > my machine won't post.
I don't understand why the 8.5 multiplyer setting will work using higher fsb setting but the 9.0 multiplyer setting won't. I also tried the combination of 7.0 @ 133 giving me 930 mhz but that failed also. The highest I've been able to get my rig to go is 8.5 @ 111 for 943 mhz. That was stable but I can't fathom why a multiplyer setting of 9.0 won't work! I don't really like o'c my pci devices and that is why I went to 107 fsb.
Is this a problem with my mobo or my cpu? The CPU seems to be able to handle the heat (46C load isn't that much), what do you think?
Any suggestions would be helpful.
Thank you in advance,
~Xeo
CPU Voltage @ 1.75
~Xeo
