- Nov 11, 2006
- Tampa, FL
Ok. I ordered 2GB of Memory from newegg.
Crucial 240 pin DDR2 5300. Every time I put the second stick of memory in, windows will not load properly, and I am told I need a boot disk because a .dll file is corrupt or missing.
So instead of the dual channel set-up for the memory. I just stuck the second stick right next to the other so it is in the DIMM 2 slot. With the 0 and 2 slots filled, I still had a problem with it, but I could get windows started in safe mode.
Does this mean that the 2nd stick of RAM is explicitly to blame? I need to send it all back to newegg, if this is the case. If the RAM isn't to blame, then I need to figure out what is.
Next I am going to remove both sticks of RAM. Then I am going to take the "bad" stick and run it by itself, to see if that is actually the problem.
Any other ideas? Has anyone else had a problem with Crucial's anniversary edition 5300?
