problem with onkyo!!! replacement not workin either
d94
$30 a phone
i got in on that 5,1 surround deal for $133 shipped
got it, 2.1 works BEAUTIFULLYY
5.1 sounds like *** regardless of the input
i called them up and they said the receiver was busted, so today i got the replacement...same EXACT problem
somebody PLEASE tell me what im doing wrong :(
Well... more than likely it doesn't sound as good because there is not the same amount of wattage going through 5 speakers as there is 2... so basically the speakers aren't getting the same amount of love as the 2.1 setup.
Contact them again, could be another busted.
Plus we have no clue how you set things up.
So contact their Custemer Service and let them walk you through it.
Whats the source?
What exactly sounds bad about it?
Are you using any sort of effects/mixing? [PLII etc]
Are your delays set correctly?
What speakers did you run it on?
I am guessing you either has the SR303 or SR304?
65 watt/channel is not exactly will be putting 65watt/channel when connected in 5.1 setting.
