i got a thermaltake 12" cathode case light. put it in and all seemed fine, but i noticed when i turned it on, the fan seemed to drop in rpm's a bit. then, after a while (a few hours), everytime i'd turn on the light while the pc was running, it would turn off. the fans would continue to run, but it would shut off and the monitor wouldn't even show anything. as soon as i turned the light off, the computer will restart. i know it cant be a shortage of power, b/c i unplugged both cd drives, both hdd's, and the floppy, and all i had plugged in was the dragon orb pcu fan and the light. i still received the same result even with JUST these 2 things plugged in. i dont know what the problem is or if something is wired wrong of if something is wrong with the light. its a mess
also..the switch for the light doesn't have a ground, so that can't be the problem. please help
