- Jun 28, 2002
- LITTLETON CO.
i just bought a wdc 40 gig 7200 rpms for my raid array,
i first tryed to format it on fdisk but it locks everytime i try to do it!
i also tryied part from ranish and seemed to worked ok but the drive still not been detected on any windows (either xp or 98se)
of course i always test without the raid controller but can't make the thing to work, i had some luck installing win 98 se but the first time siad it had trouble reading c, then after making a fat32 formatting on part went ok but it seemed to lock while checking the allocation tables at 5% i waited for 15 minsand nothing.
same thing on winxp while formatting to ntfs....
WHAT SHOULD I DO??????
