Hey everyone,
I'm kind of a noob when it comes to overclocking anything newer than just increasing the FSB, but I'm trying to learn how to properly OC my system.
I've built an ITX system using a Ryzen 7 8700G, Jginyue B650i Night Devil motherboard, and Juhor 2x16GB DDR5 6800MT/s 1.4V (Hynix-A chips) memory.
The CPU side of the APU is running without OC, but I’ve enabled Curve Optimizer Per Core:Core 1: -22 | Core 2: -46 | Core 3: -37 | Core 4: -39Core 5: -44 | Core 6: -37 | Core 7: -36 | Core 8: -42
The GPU side is completely stock, but I can OC it to 3150MHz @1.25V.
The motherboard is running AGESA 1.2.0.0a. (There's a new BIOS update, but it doesn't mention an AGESA update.)
The memory is Juhor JHE6800U3416JGRGB, rated for 6800MT/s 34-45-45-108. This is listed as achievable with both XMP and EXPO.
In the BIOS, the best stable setting I managed to get was 6400MT/s 34-37-37-36-48 with UCLK DIV1 MODE at AUTO. When researching this issue, I found two people who managed to get the same 6400MT/s with MEMCLK 1:1, and both mentioned it's possible to achieve higher clocks with MEMCLK 1:2. However, when I set the clock to 6800 via EXPO and MEMCLK 1:2 manually, the system boots, but Prime95 crashes right at the start, and then I get a BSOD.
I have two kits of this memory, and both give me the same results.
Is there anything I can do to first get 6800MT/s stable, and then possibly overclock beyond that?
Thanks!
Thanks!
