Hi guys! First time posting here! How are ya?!
This is going to be quite lengthy. First, these are my computer specs:
- Asus P5Q LGA 775 Intel (P45/ICH10-R)
- Intel Core 2 Duo E8500 Wolfdale Socket 775 (45nm) @ 3.16 Ghz & Artic Freezer 7 Pro Heatsink with AS5 Thermal Paste
- G-Skill 4096MB DDR2 @ 1066Mhz PI Series
- Seagate Barracuda 7200.10 Sata 3.0 Gb/s (160 GB) + Seagate Barracuda 7200.10 Sata 3.0 Gb/s (750 GB)
- XFX Radeon HD 5770 1GB GDDR5
- Creative Sound Blaster X-Fi Xtreme Gamer 7.1 Channels
- Coolermaster CM690 Mid-Tower ATX Case & Cooler Master Real Power Pro 750W ATX12V / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Power Supply
- Windows 7 64-Bit Pro Edition
- I also use an APC UPS Battery Backup. Don't know the ratings but it keeps my pc on for a good 10 minutes.
First things first, my PC is highly optimized, no virus, i defragment it every two weeks, latest drivers, latest windows updates, run ccleaner almost every other day an AV is up-to-date (AVAST). I clean the dust every 3 months so no dust inside my pc. Yes i know I'm an OCD kinda guy! I have an array of problems in my pc so i want to enumerate these problems. I also hope that you can help me narrow it down so I can find the culprit of it all.
1. Computer shuts down randomly. It shuts down even after 2-3 seconds of turning it on, or even after 5 hours. When it turns off its only a matter of seconds when it turns on again (from 1 second to 30 seconds). When it turns off, I can't manually turn it on with the power switch, I just have to wait till she wants to turn on by itself. Sometimes would I hit the side of the case in anger and the computer turns on again lol. But that doesn't happen all the time. Yesterday i used it for 5 hours and no random shut down happened. Somedays I use it for long periods of time without problems. Sometimes it happens very constantly. Currently inside Windows OS no random crashes happen of any kind (applications, error messages). The only crash I've seen are Blue Screen Crashes but are not constant (kinda solved...see point 2) Possible Reason: RAM Faulty
2. My sound card started making this weird high pitched noises and having driver problems. I usually uninstall the driver, run driver cleaner and reinstall same or newer drivers and works real good for about 3 weeks. Then after that it starts all over again. Last time it happened it didnt even recognize the sound card so i uninstalled the card and am using onboard sound. Since then, NO bluescreens, NO high pitch noises, NO sound problems. Prolly a bad sound card.
3. Sometimes out of the blue, my pc would not post. No beep whatsoever. I would take out the RAM and put it back in and it posts. It Happens every now and then. The inside of the pc is never dirty plus I have like 7 fans inside a CM690. So i would say heat and dust are not an issue here. These same memory sticks i tested. Single, Paired, both of them. I used Memtest 3.7 to go through 1000% on each stick (Not Memtest86+). No errors were seen after basically 10 passes each.
4. Sometimes on startup the motherboard would say something like "Overclocking Failed, press F2 to blah blah"... I usually hit F2, load my saved
preset, restart and it boots fine again. My BIOS is updated to the latest firmware. This really doesn't bother me, but wanted to point it out in case it helps to solve the problem. Also, my pc is not overclocked, just set the memory to 1066 in Bios because it is not by default and turn off some innecesary settings on bios. Possible reason: CMOS Battery is faulty.
5. For the last a year and a half I would use the computer, and then after being done with it and shutting it down, I would flick the PSU switch to off. So NOO current/voltage enters the mobo. I'd do that for that whole year and a half. The thing is, i dunno if that is harmful to the PSU. Then like 3 months ago I went to turn on the computer and it didn't remember the bios settings, i re-entered them, used the pc and flick the button again just to find that he next day that I had to re-enter the settings on the BIOS...once again. Possible Reason: CMOS Battery or the PSU being faulty.
Still there guys? Haha. So that's about it with all my different pc related problems. That's why I have reached the conclusion that it may be either the CMOS, PSU or RAM. But I'm asking you guys If you may have a different opinion or advice (For all we know the MOTHERBOARD may be the culprit). Or Could it be the On/Off Switch on the Case? Many thanks in advance and I hope to hear from you!
