Hi everybody!
New user here... And new build!
Started with a sabertooth Mb, that seemed to have massive issues in general.
Now, P9X79 with latest bios
i7-4820k
Corsair 16g Ram
2 Geforce GTX 780 ti
850w power supply
So...
Was having massive issues keeping the system stable, as i would use it. I would never get blue screen of death, but would get just system drop off, and no restart. Would have to power cycle the power supply to get a reboot. And then, would only last for about 20 minutes. I thought it was graphics overheat, so i turned down the cards to 50%, and fans up to max, so the cards would sit at 60c working temp. (They are built to run at 80c nominal) No difference.
Swapped my power supply from a 750 to a 850, and that seems to have solved just about all issues...
Only problem now is, i cant overclock my chip, which really... is fine at this point, but cant seem to figure out how to turn off overclocking on the P9X79. (not pro) Funnier thing to me is, if the chip is warm, and system has been on for a little while, i can overclock it to 4.5 easy. (from 3.7) and it will run stable until the system is powered down for overnight. Then restarting cold, i get hangs on windows boot, overclock fail messages, and about 5-6 or 10 reboots required to get er up and running again. After running stable though, im all good for the rest of the day....
hmm...
Hi all! Glad to be here, and hoping to learn something new!
~Guy
i7-4820k
Corsair 16g Ram
850w power supply
So...
hmm...
~Guy
