Problems with KT7A voltmod
Mr-Smith
Norway, AAlesund
I have voltmodded my MB, I have done the pin7 mod (used a 100kohm pot) and pin10 mod (50kohm pot)
But when i go over 2.15 v my computer reboots
Without pin10 mod the same happen at 2.09v
any help?
AntiHeiss
Senior Member
Texas
Sounds like you've just hit as high as your motherboard would like to go with that voltage. 2.15volts is an incredible amount really. If you can't get your overclock with that, then you reached your limit I would think. But thats just my 2¢
And by the way...Welcome to the forums, and thanks for finding the right forum for this question. Good call. :D
Sonny
Senior TIFOSI
VARIANTE ASCARI
Pin 10 is suppose to be the overvolt protection mod so if that was set properly it should be able to let you get 2.3V or so. A few things to consider;
1. Heat
2. PSU stability, Capacity/Quality of current
3. Pin 10 pot rating
