Alright... put my computer together:
AMD Athlon XP 1700
Epox 8K5A2+
Thermaltake Volcano 6Cu
256 MB DDR333 Ram (KByte)
48x12x48 CDRW (Liteon)
Maxtor 20 GB 7200 ATA 133
Geforce 4 MX 440 64 MB DDR (Chaintech)
Windows XP Home
80mm Rear Fan
MBM 5.2 (not quite sure how to set this all up yet)
Floppy
Using all defaults computer runs fine... boots fast (compared to my 700 celeron with ME)... no problem (haven't gamed yet). Runs at 41 cpu and 27 case. Have not updated windows or bios. Everything functions fine (all drives etc...)
Problem: The cpu is running at 1.1 Ghz. Should be 1.47. The CPU Clock jumper is in the default 100 mhz position and bios at 100mhz. Supposed to be at least 133 to make the 1.47 (133 times 11 multiplier). If I change the jumper the monitor will not turn on on boot. If I change in Bios same thing when leaving bios.. monitor turns off. If I do both (bios and jumper) same thing. There is CDRW action and some other whirring... not sure if the hd is continuing to boot. Have to reboot and unplug and press insert and sometimes wait a while before reboot will work... after a few tries often. I need to get that CPU to 1.47 at least. Should be able to get it past that on a 8K5A2+.
Thoughts:
1) Is my Geforce4 being stressed out (AGP) and should I change its defaults or overclock it somehow? Should be able to handle a default 1700 at 133.
2) I have an older TTX monitor I got with my Pentium 166 a couple years ago. Is the Geforce4 overloading it when switching to 133 CPU Clock. (Did update Nvidia drivers. And have made display not turn off... forget if I tried that it was late last night and I had given up and just become satisfied with 1.1 for the time being for continued setting up of programs). Will buy new monitor next week (didn't have the cash to do all at once).
3) Everything is fine as per MBM or PC Health monitor for the motherboard and cpu. They aren't sweating. So I don't think its a bad board or chip. Its somewhere else I'm sure.
Thanks in advance for advice... particularly if you solve the problem.
AMD Athlon XP 1700
Epox 8K5A2+
Windows XP Home
80mm Rear Fan
Floppy
Thoughts:
