AMD's PR system has been revamped several times since the introduction of the AthlonXP.
The most accurate PR comes from the XP2400+ T-bred B which operates at 2GHz and is more than on par with a 2.40GHz Pentium4 B CPU.
Almost no AthlonXP has a PR suited for the 800MHz FSB Pentium4 PCs. It just wasnt designed to rate at such a performance gain on the P4 side.
The current Barton 2500+, 2800+, and 3000+ were all meant to challange the 2.53, 2.8 and 3.06 533FSB Pentium4s and beat the P4 in majority of the applications.
Actually, the only CPU rated to go against the Pentium4 Cs is the Barton 3200+. Although still vary overated, the 3200+ AthlonXP outperforms the 3GHz Pentium4 in alot of stuff.
The newest rumors that I've heard are, that AMD is launching two more XPs before it ends the era of the AthlonXP. Those are the 3400+ and 3600+ models. The difference between these CPUs and previous Bartons is MHz. These two chips although should be clocked at 2.3 and 2.4GHz are instead clocked at 2.40GHz and 2.50GHz.
A PR of 3600+ from a 2.50GHz AthlonXP is also pushing it but seems reasonable.
OC-Master
