A couple of points from my chair here....
My production is up for a couple of reasons.
First off, William is now Folding for Team 32 again, under my name. He started doing this almost one week ago (3/24).
I replaced the P/// 700E @ 933--Abit SH6 combo in my "3rd rig" with a T-Bird 1.0 GHz @ 1.4GHz--EPoX 8KHA+ combo. I did this about a week before the XP Contest started, and the stats have reflected the significant gains the T-Bird makes over the P///. It's common knowledge that the T-Bird Folds faster than a P/// at the same clock speed, and this T-Bird is almost 500MHz faster than the P/// it replaced. Kinda like the car commercial...
zoom, ZOOM, zoom....
I've been getting a steady diet of 5 point WU's for almost a week straight now. The AMD rigs make fairly quick work of these "protien A's"...
The "sig" below shows my P/// rig back up and Folding, as "Rig 4"...it is not. I've got 2 WU's stranded on that machine, which is down right now, with some problems. I'm short of drives for that rig, and will be swapping in the cd-rom and floppy from one of my first three rigs sometime this weekend, to square it away. I thought it was a bad NIC, but I pulled the NIC out of "Rig 2" last night after it finished a WU to see...nope. And I need to install a cd-rom, as it appears to be a WinME issue. I've been hesitant to make any changes (and there's a bunch of stuff I
need to do on these machines) while the XP Contest was running. I was the only one with a shot at catching Gandalf, but the "fat lady" has sung. I've moved up as far as I can go before the contest ends, and I'm maxed out in 2nd place. He still has the potential of moving up 10 more positions in rank... End game. May I be the first to congratulate you Gandalf....enjoy the XP1600, and put it to good use Folding for Team 32....
On that note...someone mentioned "Let's see who's been "sandbagging" and who's production drops off after the contest ends." Let me say right now, the first few days of next week, there will be a drop in my points, for a few days, while I square away the PSU, HDD, and other minor issues that have been plaguing my main three machines for a couple of weeks now. So over the naxt few days, I need to do a three way PSU swap, and then run a full diagnostics program on the HDD in "Rig 2", as three times in the last week, it's locked up with a "Cannot write to C: data may be lost or corrupted" BSOD. Might be the drive, might be the IDE cable, might be a WinME thing....gonna take a format to find out....=(
Then, I just got a used cable modem/router, and want to test that out, for when I build the gaming (NASCAR 4) server I want to get running this summer (using the P/// combo).
So if my points drop off after the contest....I'm doing repairs, not "sandbagging"....
B.
