I'm trying to read your mind to see the entry, but it isn't working right now. Must be because you are offline.I looked in google cant find something that says what it is as far as software, I'm wondering if "program" in startup is malware. OS is windows 10.
Yes full scan and most resent updates.Have you run your malware/antivirus application to check?
Do you mean the registry?Did you look to see what the path to "Program" is?
I'm unable to look at properties in the start task manger it is not highlighted for "program".Hover mouse over it, right click, select 'Properties'.
Click on "Program", and then right click on it and select 'Properties'. My guess is almost certainly malware of some kind, but you won't know unless you find the path and see where it resides. Unless it's a program that started up with Windows that got uninstalled incompletely, leaving that entry. You can try looking in the startup folder (open File Explorer and type "startup" in the search bar) to see if it's there, but the startup folder doesn't get used very often anymore anyway, from what I've seen, so you probably won't find anything worth noting there.
Without knowing where Windows is looking for it, you won't know what it is and how to fix it.
That's suspicious.
Please, elaborate.
Wingman, do you see anything odd in your AppData or Program Files?
Anything showing in Programs and Features?
