Pharaoh, a simple trick I do for wiring like that, is to use heat shrink tubing around the posts after you solder it on. It helps keep the joints clean and provides some slight mechanical protection as well in case you drop it or something.
Also, when you go to lay everything out, cut your wire over length by about 50%. Then solder the wire to the most mechanical stable position, and you can use a drill to twist the wires, creating a very neat and tidy wiring job that will actually hold up better in the long run.
Soldering is 50% patience, and 50% art. Takes some time to get good at, but over time your joints and soldering performance definitely improves. A good soldering iron is pretty vital as well. Stihl makes a fantastic variable temp soldering station for not a whole lot of money.
http://www.amazon.com/Soldering-Sta...sr=8-2-fkmr0&keywords=stihl+soldering+station
i own a 150$ Weller station, and to be completely blunt, the biggest difference for me are the tips and quality of the station itself. The stihl "works" just as well as the weller.
Thats a pretty good price for those
I think I payed 10 bucks for just one flat tip tweezer. edit: ah, those be some chinese ones.
http://www.aliexpress.com/item/Free...ize-Vetus-ESD-Tweezers-Tweezer/728714139.html
That and some anti-static soldering tweezers. I have these: http://www.ebay.com/itm/6pcs-Safe-Anti-static-Tweezers-Maintenance-Tools-ESD-/200794457707
I didn't buy them from that guy, I have no idea what sort of seller he is. All I know is that I have a bunch of VETUS tweezers and they're great for the price.
