- Jan 2, 2015
- Sydney, Australia
Hi guys,
I'm back with another case mod, this time with Corsair!
I'll be using their SPEC-ALPHA case to create a special case mod to showcase the new ASUS STRIX GTX 1080 graphics cards!
This project*will be inspired by an HRC (High Resolution Computers Shop) build in the same case. For those that don't know HRC, you can check out their page here and the SPEC-ALPHA mod they did here.
When I say inspired, I mean the open-frame design of the build, I'll be doing some things a bit different
I'd like to thank NVIDIA ANZ, ASUS ANZ, Corsair, Bitspower and CableMod for their support on this build! I'd also like to thank all those who follow my build logs or follow my page through social media and share the same passion with me! All my builds would not be the same without sharing them with all of you!
I'm on a very strict deadline to get this build finished for an upcoming event so the build log updates may sometimes be delayed to what I'm actually working on.
Hope you guys will enjoy this one!
Onto the SPECS:
CASE - Corsair Carbide SPEC-ALPHA
CPU - Intel Core i7 5930K
MB - ASUS ROG STRIX X99 Gaming
GPU - 2 x ASUS STRIX GTX 1080s
SLI - NVIDIA High Bandwidth SLI Bridge 3-Slot
RAM - 64GB Corsair Dominator Platinum DDR4 2800Mhz (8x8GB) with Light Bar Upgrade Kit
SSD - Corsair Force LE 480GB x 2
PSU - Corsair HX1000i
Custom Cables & LEDs - CableMod
Custom Watercooling
CPU - Bitspower Summit EF
RES - Bitspower Water Tank Z-Multi (Clear acrylic)
PUMP - Bitspower DDC Plus with Bitspower DDC Upgrade Kit
RAD - Bitspower Leviathan Xtreme 360
FITTINGS - Bitspower Matte Black - various
TUBING - Bitspower 12mm Acrylic
FANS - Corsair Air Series SP120 Quiet Edition x 4
COOLANT - Mayhems Aurora Silver
I'll start of with a pic of the Corsair hardware all together! I'm also planning on doing a few video updates for this build as well.
Stay tuned, should be an exciting build/mod!
Cheers,
Alex
