- Jul 13, 2007
- AR-USA
- Thread Starter
- #41
Ok, there has been a lot of discussion about why I don't just put the radiator in the pump box. Yes there is wasted space, but there is still not enough room to fit it without it being close enough to the pump to heat soak from the heat the pump is putting off. If you have never used an Iwaki you might not understand, but these things put off some heat. The case is not wide enough to fit the rad on either side of the pump so it would have to go above it (the bottom of the original case). If mounted there I would either be pulling hot air off an 8800GT or the pump (which would pump more hot air into the case) to run through the rad. Not to mention that with any fans on it the rad would pretty much rest right on top of the pump.
Any questions?
Thanks for all the positive comments guys.
Any questions?
