toolking403
- Oct 18, 2016
so the the idea is to incorporate 2 flat style rez's to eliminate the tube rez and install a ek flat top on the pump one will placed at the back were the current one sits and the other will lay flat on the bottom below the video card also alleviating my ocd for the one out of place tube running from the cpu over top of the gpu and into it also the new setup will support the gpu
full parts list found here >>>>> http://ca.pcpartpicker.com/b/tjPscf
this is what we are starting with
[url=https://postimage.org]
how to print screen on pc[/URL]
on to the test cuts seeing if the size will work. first cutting mock ups from some cheap wood
temp image upload[/URL]
the size and shape will fit the build now to pre cut the 1/4 acrylic sheets 3 pieces per rez
now on to laser cutting the design
capture screen[/URL]
how to capture screen[/URL]
working with the layout i would like to have mostly working on the fly sittting there thinking this would work but nah that would work better i layout the holes for drilling and tapping
[url=https://postimg.org/image/m590u4f3d/]
post img[/URL]
image hosting free no registration[/URL]
upload a gif[/URL]
using old pic to show the welding of the acrylic
upload a gif[/URL]
then on to the pipe work,filling and leak testing. note bottom rez has dump pipe on the bottom that leads to the rear of case with a valve
uploading pictures[/URL]
