- Jul 26, 2004
My System has seen some changes over the last few weeks and so I wanted to share my "New" system so far .
Fractal Design S
Gigabyte z97x-ud3h-bk
Samsung 850 evo 500 gig
4670k from last build
same ram as sig
Corsair tx750
Dark side cross flow slim 240 rad
bits-power rez
koollance clamps
Promochill LRT tubing
swiftech apogee gt
Heatkiller IV PRO copper
For my GFX I used the apogee with a parts from a Maze 4
Here is the layout that I took with my Tubing that LRT is great it doesn't kink and holds a nice shape (But sure is hard to get off plastic barbs! leak testing was time well spent )
This build isn't finished yet but I can game =) It sits pretty close to those pics right now . I was planing on spending some $ on some new fans BUT , with the temps Im getting right now I don't see the need for 24/7 for any more so the 240 rad at the top is passive(but can feel air pushing through it) Vantec stealth fans on the front are running @ 7v. There is the two stock 140mm fans that came with the case one on back and one the bottom at first I thought I would hate the small bit of white in this case but it is growing on me.
This was the first temp I saw on first boot with p95 and Heaven the max the GPU hit was 24 deg C
This is a 5 min AIDA64 run to show cpu temps . This OC was just a guess I haven't really played with it at all just set @ 1.25 in bios and 45muilti so I could see how bad the CPU temps were .
Here is P95 On small ffts ( have ran longer hour plus temps didn't really change )
So guestion time =)
Should I paint @ least the shroud on the blue rad to black ?
Does the Red ram kill you as much as me . They might get painted .
I have a White 30 cm Led strip that I will be adding to the bottom .
Any tips or Ideas you might have Im open to ideas
Fractal Design S
same ram as sig
Corsair tx750
bits-power rez
koollance clamps
swiftech apogee gt
So guestion time =)
