Basically the method is using a locator pin.
Put a long nail or something straight and pointy into the drill bit, and have a sacrificial piece of wood on the base. Something sturdy of course. Bring the drill bit down and mark the wood where the piece will go. From there, install something to make a pin to perfectly align the piece. Make sure your pin is roughly the same size as your drill bit you're using, I personally use another drill bit of the same exact size.
Then USE A PUNCH and mark your center point and drill a small pilot hole (same size as your pin), making sure you got dead center. Then mount the board you drilled onto the pin. Install your forstner bit and when you press it down, it will be directly centered on the pin, and your hole will be aligned to the forstner bit perfectly. Setting your depth stop on your drill bit will get you perfect depth, perfect alignment, and (pending you do everything correctly) perfectly straight holes. After you do the forstner, you can swap to your potentiometer post drill bit, and drill it through 90% of the way. From there the hole will guide itself and you can clear through without any movement.
Ah, I'm just super anal with stuff like that. You're putting all the effort into this, may as well get it perfect
Side note, anybody else been having intermittent issues getting here? Seems like since I switched to Chrome from Firefox more often than not I get "Chrome could not connect to www.overclockers.com"
Contact me I'll assist you in getting the best bang for your buck in the wood department.
I'm sorry, couldn't resist that one. Carry on!
Contact me before you start this with hardwoods. I'll assist you in getting the best bang for your buck in the wood department.
For me, If I made a desk like that out of maple, I would be expecting the price to be around the 300$ range.
Legs would be 20 bucks each, easy; top im guessing is like 2' x 4'? out of 3/4" x 6"; we're talking 40$ for the top; with the side pieces we're looking at 1/2" x 8" (guessing), so around another 40$; bottom would be around 60$. Trim peices would be another 20 bucks.
I think you are quite off on your prices. Hardwood of any substantial length costs serious money. If you add width to length, it increases exponentially. If you add quality, width, and length, prepare to bend over and grab some ankles. Quality veneer is the only way that you are not going to be eating some knee caps in a project like this. Check woodcraft.com for some of the best prices on wood and veneers. If you go the hardwood route, be prepared to drop $600-700 to do your project. The veneer route is maybe half of that. For a project like this, there is no reason to go with solid hardwood, as it offers nothing besides visual appeal. Veneer will do the same for half the cost.
That would be great, will do.
Was expecting it to be pretty spendy. One reasons I'm going to see how the OSB turns out, hard to beat nice hardwood though. Another alternative is going light on the hardwood. Maybe solid top and then veneer for the sides.
Off the top of my head:
Top is 60" x 35"
Sides are 30" x 7"
Front is 54" x 7"
Bottom is 54" x 30"
Edit: Remembered I was considering doing a second bottom to do cable management and supports, so two pieces sized for that.
Miiight be able to salvage the piece that is cut from the top for the sides, if I remember correctly the hole is 43" x Something.
Add more to that estimate, considering doing tempered glass rather than acrylic/polycarbonate for the look and durability. Found a glass shop locally that will do it, just need to go talk and see about cost.
One concern is the tools. The tools I have, while the work, they're not top quality or brand new. They were bought for rural living house work, not building a hardwood desk. Would a check to ensure good condition on the blades and bits be sufficient to do the job do you think?
Glued 2x4's won't create a perfectly square leg, unless you shave some off the width. Why not just go ahead and use 4x4s?
Or, unless hardwoods are measured differently. I wouldn't know, I've never dealt with them.
