PROJECT LOG Project Zero
Tymofar
Hey guys,
my realname is Benny.
i am building my first own Case and wanted to share it with you.
I hope you will enjoy it! =)
My build is called Project zero cause its my first scratch build.
I have made a few little modifications throughout the past years but now it is time to
make somthing big ;D
Contemplated system:
Hardware:
Mainboard: Asus Maximus V Gene
CPU: Intel i5 3570k
Ram: G.Skill RipjawsZ (4x4) 16 GB
GPU: ???
PSU: ???
SSD: ???
HDD: 1x WD Green 750 GB
2x old Samsung 1TB
Watercooling:
Rads: 2x Alphacool NexXxoS XT45 X Flow
Res: 2x Alphacool Eisbecher 250mm
CPU: Alphacool NexXxoS XP³ Light
GPU: Alphacool NexXxoS GPX
Pumps: 2x Alphacool Laing DDC310 + Plexitop
Ram: Alphacool D-Ram cooler
Fittings: Alphacool Eiszapfen
Tubing: PETG
Fans: ??? dont know yet, and dont know if i am just going to make a push configuration or go straight push/pull =)
Current status:
y3m9s3jCcVclm74zb7c6ACeOTH2e0nhDP7dA8pX3VygpuiOe8BKqMnIp_AGJwSnPr87gUUMHdzI03nncqZUfvlSlR3nH1r0jAYsdjFAjABqtE3wT2hx4Magd_qa0LkTqvUdR6sOINjROGdfv90p9YgFmaoyJbfJDaLuq0zkNzszpNc
y3mFP5CGokGjC7EtExTDxkFyMPzjBQOoq3hbhWKsZ5bOdEOPz7QwBJ6kUxA2CDMp1HOciKBw01CopwGBM9miZyF6H04Xs-RewVY0Exq2qh8kUiYvwVxFhx1KpMg0fVOqIG1Jqxfvd85zpzGi-ntgYmbSJEFrAwzdf3KNoBVUrx2fiI
Here is a sketch of my Imagination:
y3mWNwY8V4vfRzb6l4jFrXUTvk7UPO7AG6rtX0Y7KURMUkEQ8EuU3_Mj29IBJjPO_vBNdXG-TeIGR_HgDeMt4XV3nrr41dA8bnkKx-slDwL-o_jjYco122C89OtMzftyppxv0DoiiQ0FiYRT1xDc4VDSqOdc3GNUZTnZPLTVnlLLOA
A friend of mine was so nice to make some renders before he went on holidays. Due to the lack of time
he couldnt finish them, but they will help you to imagine what i want to do.
y3mzwQ2D45JTihZS3cFWK33qMdwOPPPwYzr1K8VeoYDJLPuXpDhMdv9a4X_4LVuA7FlFhqXHfXjKxoPbCfqtcb2AhBcyJiyPUdMJVOBxJfPB2VMObnBSFzH4ciKmVVLBLCtfrR6wFrIn8vNMJG2aNoi9pB9XVdURKVji0XAbScROjI
y3mDR8_s6_dK_YZusbpAKvnANNRj2y18J8pz-g9bjxXzv4zaYqbniVspRW9O6FQPZCA_jJ7__APtI_vvm128uJCsxVyizXkN_fMXefJ9eTbn-XlNBPZKOtP3gz9OTVpLLPwpbV3xXoCnjQNxBBMeDTNHCgRjsDB3CrVNOEHRE9ufC0
Thanks for that.
The finished Case will have the following measures:
64,8 x 64,8 x 25,8
Materials used
aluminum slot profile
aluminum plates
"Dibond"
Plexi
So again, i hope you will enjoy it.
constructive Criticism and Opinions are welcome.
greez benny
- - - Updated - - -
Here are the photos of the slot profile which will be the frame for my case.
The profiles are 20x20 mm
y3mG_QblHtgaAskkOwZOIQHjfTcIal-6GphBMCnuv0d3hrzZ_vLJu_y2fDDRIM5I4mSMAxeMvwP73g7v3hdLkcFr6rzCKm7X6Oe8tfCDJNKk3wmAniQuQyBTMrqHVq7y52-6qZdmx2U6fGcZl8KCVkpKvEJWLq1UaaophfqtJdBEb4
y3m3qbef2MGaUYVN8EHtRfYJvtA3cGuEGC1uoT9_arXkOwVs4gN4jibQzHTMPnhyz4UhpQSf83cQdulo9YpFj9BCXqXu3CvgkgPYfDA-iagupKWsLOO9POkmpLvsr5ktYWNFgqG3tYZXvhNvPPDB1x2ByaTcM2e1yMv4z0c3zNQxxI
y3myq1rOFTHv0cPrL7VMObpxrMyd6yaZE4ViNTfOiGuiYqf9wbh5cb0rK8YXBDfewwTzgPvrhz1ue1UGOUK1ISUt-NbCNTezsqkCPH60pTYrK57Itju3xn76MTNkxTcWxBUErFFVjTztSo2pav770skf9h5TBbRTrnQyctr9sXHe8U
y3mA_0FtvMumMwX2BnvmLwZz2nGOwyp-FhqDQvAHSaNXK2MloNf6zmxaoMqPvCJ-DOOyJgzmoFo2z2mPlroFGFGhCoGd3KyCMFOsnaKYMWXr9WTqhJF-hzYpAhUoRSNFa44C9_qv_Jso3g80SHt-gBvxVnnOYBcykk0nsNKKzNLt0g
y3mHW2uyNar9vl3vrl_nsRycVw48OdjHl9m86A_yTMvfeTvwoNR2aFJ3qUw87OC5E73ExS53s8CExtJY23qU_Y7EsaLoj9hCUCjXsUBU36wa1qAE6WIIkm80R2J40KS7Bf5yQrO_iha2ejRJZpI68htE_ungkcxA8W7qKgFgc-nrb8
y3mvb5VgQrp1fThTWLTWN2xa81arxP0_y7KbOVDn3eaY7kPJBrEdJgv62fpFqLsi7YyFm-woDwsG1j2FLylU514qLlbGeca0oKXKaz9vyGHRBWNKp5Sf2E6CdqOf3apQAQHI8pFPvziJ-2dQbupJbAdXcuBrhWiNUIRub4JmXn9Jm0
y3m9ptJug6eMrpnQGmjuABe8B9zBt-AGI0dIzhUfy76hc-054ZwID2eFGVK3EMl0EUO-ON6S03l2xq4RmbWVZ4gM9KjYn2TnOZcvr4zKllyUPEXdshmgXCAoGJqyOlW0DUnByChcwktE9SI8W76s3Q-3enqkYf8MvRDwp234c1JrpM
y3mAVANxN9xb-PdVIVbl3N7a-QxHhBCOWU71-1l-YL6ii2geCJKb4UKhJCGul1slnkgGqw15kzHCRh0SxQuDbn6IkS_LGJ7ugRI4l0xdKY8iUudvN_-rguo8XmaZPsMXAprNT-Lj8LgNnZ4mpzQwCR5uFjCvmQB2moHWA9yAfJzEic
Lochekey
Senior Pink Member
Hi Benny welcome to the forums.
I have been interested in using that aluminum profile for some projects so I will be interested in seeing what you do with it and how you like it.
Wanted to ask what your plan is for internal case wire management and are you planning on offsetting the mobo treaty so you can route wires behind it.
While talking about wiring. How do you plan to manage the external woes like the keyboard, mouse, etc.
Based of the dual reservoirs and pumps I'm assuming you are planning to do dual loops. If you are just doing it for looks I understand. Otherwise have you considered a single loop as they are easier to manage.
Enough from me for now, looks like this will be a good project and will definitely be watching.
Cheers
Silver_Pharaoh
Likes the big ones n00b Member
Sub'd!
I originally wanted to use extruded aluminum (80/20) but found it was expensive and that 1" poplar square dowel is just as good :)
Can't wait to see how this turns out!
Tymofar
Tymofar
Thank you both!
For now the profiles are very good, really stable this will give the Case the right stability. so you dont have to worry that everything collapses if a butterfly lands on it ;D
The only thing, the slot stones are very tricky. As you can see i have two different versions of them. Some with support strips and the others without.
i recommend the ones with the strip.
Tomorrow i will add some pictures of the frame.
Wire management:
first of all i will sleeve my cables with paracord.
The Motherboardtray has 6 cm space behind, so i will hide them there.
For the external wires there is a hole (you can see it in the sketch - there is a rectangle right above the MB) and then trough the back of the case.
So you dont have any problems on which side your pc stands.
i am thinking about making a Cover but how i will see when i get there.
Any Suggestions?
Yep planning to make dual loop. only for aesthetics =)
I want to use two different coolants. (red transparent and clear)
Yeah a sinlge loop is easier to manage and of course a little cheaper.
@ Silver_Pharaoh
Yep, first i wanted to use another profile anodized black (makerbeam) this has only 10mm x 10mm.
i mean i could have used that but i think my profile on this dimensions is a little better when it comes to stability. (i think ;D i never had that makerbeam in my hands)
And its a bit more expensive than the profiles i use.
I found a company which cuts the profile to the length you wish.
greez Benny
Tymofar
Tymofar
Thank you too for subbing =)
Some new pictures i made today at my parents place, of course i took the chance for a sunbath afterwards ;D
First the assembled frame.
y3mQ67hWwtmiTEbkw1MBvnE5XYSUGIBNTL4kB184K00hPKUth9C9svrPk0Qgz8D_KuqS2HQtQVoaVG153AQM2_yynXNCQ7aV6t7hM98Kii0x92jJn5amhEGXhh3R_IMI-cSVOyCEGwbZu3NBc5UzTnPZ0hk_IhxJ6nscZLFtT-90mQ
y3mv1fjMUg0M_WpMAuFFkvtS96MH43dpNPuNNrR7FxGS5rE_BJKWkmwxLG7bWXs-cGqJLY3r9cGiV8yNoNixbm85D-9TN2RTdjMUOYvmPXdk_L8aoPUzqHZr2dKVJAczL8HpCZtdXSM3cmXj_IC6VJD73mchU2KJvnJXrPcRpyfKqU
y3msMGYfBDknzECYuG_FMBQFXTJV56YzZ9BMh3GeVIKLdXBL8ie8ZOblPjAzL0OWSEEJWT17s6lX5gL9kWsMCk8DRo114TNmP2xqBARq5bYno_Mjt_LMEv984-VA76mcEH_IQOPpBn7sVfrjLTQpk1rhWQ_NVHJa5oSASLdg_YK2CU
y3mb-CkTWgs6CnuitVtU5fXvbiufWKE1L-9rtcRe8FHkY0Tr23MDjyy0ab5aaUqIgpvigPPRF6bNPk6PvfgEevUHrp-7RQNkp1UAngudK2WBfHcWbk5Z5q0rscIOBBs0GTDSpySBMAiaFMLIE6Lx2Bju0Mp7c3H3WZcyoSVb2sN4V4
y3mm-NIoXxOXDo3oOoBJFk4q7Eluzc6ZGto20RPg227-UbZMGbdZ9BidaUtR-71oaCDKZv_Pp2jp6oTJjNIC6WCsgArBcrHgOpyEchy7cBqrZfYSUZy2Sd4wPHquTV0OKyVvQHBUflggn-ZsLRVJfpiP5SnQhdbu16pWZ2n7-jlFHo
y3mPMf91JJ2QRnY74-9z3_sqkDxJF_lHu84XXuMOoYycOM1ZrlCDMyFopj9j8JzEmAjG7m9wpzeZ8EtQsYLGbecr4VUZWWxHhpRAK5UzdAH1FT0m-wcOwziAqOkKwkZPOch_W2SZ-Bw028axnxgk29knYpEQhAIWrJdpFm-RuBTfZk
With the plexiglas and the Dibond on it (of course there are still the protection films on them)
y3metAcv-o1vG4EWtNpjDkBUztuIZ0Ts8BnH5-W8ZGhnYrBsjaSf4Fd7jxYvqpwL8f4iOEZvGHcpGiSdKnGZqt9Bv149QGbE0sDboef1xARza-AOp6xF-32eMFoKCkrjmOM_k3AayeScZpmuCiVIT2B_7LSjrJdFhe6R-c5UgRetP0
y3my_RearIbiAR-zunLE_v_LXUb9k76rUf2koYwp7bSbLHDCmdFWJb96bMwm1T7GouUg4qYDEk0fUyIUaQcOqOIfAkkBIC9m4spB5fmn1YMie9dkm6fo59Ubm81lUJPOu9wN9ysDfvnHMF7smz4VqEygK1hC11nRA7ZT3AEPU8uPPg
This is the Dibond which has a nice so called butlerfinish (brushed) on it
y3mGTwLBsyXPlCu65QvFhJXVW4okiXbS-g341sUJhb0ODdJJlR3AgAE6J1tGCAz8DdSdoeFdJZhupnmMTX9-FoyGCUjx67vb_ueqVg6kYc9CcbKUV4F0iIogxj6H6HLYRaBSbgIZ54rT7-YUU7LUbHFyyODxpTYMqFhJyrBNT-2PqE
Some countersunk washers to decide which one i will choose.
What do you think, which one should i use for the outside?
red, black, natural or titan.
y3mMx1mIfckqONaKvNj1iXgmxyxoVdnwa-SgZDozJ3c4B7QEn93ZsXlEv9kJv7TXZmWOkXdG2AffSBaqQ2SxaBd09heBIP04NgTzycvObFfGNv7-v4Qjm9UssYazs-Iz4LIkFYihL1OTatPcSmPKCHKzWIB-4v_lVeIwU49eUyjLA0
y3mb5XXaKJbD5jMlBO2itoltaqCFq7ClZHHK8P2PsnS6VfCPTxt91gHUryuS7-yI8eVhoBOXvN-9olh86WiR9UDFSovp7g2-mI9Zm-bhradBMC4W5haGNziMg0wGfFBWyAESb-Bflu4eR2UTafyKjyLM4kxKJR_RGhoHmSZTDm9PMs
y3m6W3NSLoPmLACTwyqJJ0JlWoQ7DCn-3YMq4uAakSGlrwSa6pyxgTW7ekjdKwWxBgcejT6CXMRJ_v2uB5v4JAyCTfUwjqyYbNO7lEXoYIaVoDzFDmtLXabcaRogZWbwO2DPgXZxjH1dnYSoYmvwopJvSF_CY4biTktmJGBX_NCaH4
some different screws
y3mFlQSRrA6Ljo0xZqeDqj0sNzDsOlayoX9_JJkPc7xdPagE8w70E0FRD4zKnN9zSgNOKe1LE0PxMkOEk4IzUmdGuKb-3AQ9QYzQgmaRBYZnUkTrpqRS_Bgg3AQVS20_EqhxFdoAZucKXkjT59oMHgQY6nOHMHzQkNfiAemr7eWztI
and a Cablecombo piece (also just an example)
y3mhTO6zYuhjMX4asP7dOzykWrXCoXJuN6cL9ru6W_es1nD14RDCuahnXSB-XU9FHGykHiqY6YWhX21a9gnoBeBt7lq_JRzzBM02_y7BG3L20xihf8vECSBW-tKSZuJwQWeOaAWE77nFasPXdYKa-hKzDOE33gv4U1f0atDea80_0c
also i went shopping ;D
y3mZwN6VV80a7VrqdbITQNIXObpSkrHicb07ZT_U2CzYI-Ke4U0LpfuNCFf9cgl6HCIdwyo4sw4NIiqMYZGGXyDNw8zsmf47D8TTDwsIsdSBnpWRLJLA6RhxDy3Io2WxTi1kSxyfr67a9dr_YyRmbXZqd8OUxU_dwaHsQ-5Otst47E
and my Paracord for the sleeving arrived =)
y3mhzBGmghTP6WzBruZ8JC6qQNwm_ltRRBksuy1O14ZZvZAkJZnHx5LJ_-6MEoNOjHHg41fYnUHtQW7o3TrYVlGR2UwJZumMbgpxNoBB6u3yYg-HCHrgDKTJMh9ZVgPwolxWKPcQWOCZ5QEKnhsbU1kByFeqMDwRCi8WvpbDhH8Nek
y3mClyrpaZgx7rFSpt9ylW4-jg2oQvF9D7CyBOVW8iGwvJFWTQJSlWaDNmP_KQv3jMDFBIMxwi1S35DggaVWBA_NDE0y_KBuuu9Hjo0I3kkcP3zoFVeC0fu8UOEpp36elFvD6V7Nnk2bRclNOU-yZn5pC3lmTm7zVvbNtULamcKbnI
y3mqMn2B5hLMlpLUPnQy6_aQuftBX78_5JbMH5ejS72OmsTq2ECoRCA2wPpcezdQ5-bCnBYuFaZ_bzQlhoD1IKyxtOk049azgfjBxVS4w28ciciVywIqZHSIp7I9qYzt8eZQrcpFAUPtedYa2Wrh3xG6jA-fWXorjvDrPDHzKe_7CM
stay tuned ;D
Tymofar
Tymofar
Red is top, this was my first Idea but i wasnt sure if its too much.
So two for red =)
And lochekey, what do you mean with copper? there are no copper ones.
Lochekey
Senior Pink Member
So two for red =)
Third one down on the left in the first picture. May just be the picture or my monitor, but it looks like copper to me.
Tymofar
Tymofar
Ah okay, it is titanium. It is a kind of darker silver grey.
Tymofar
Tymofar
Progress =)
i got my hole saw with a 114 mm diameter.
y3m34Q9oB1uFUVylLSU9wsRrgQ_b4kqiEJCwdH9lZZ0uh-PqMP2HqVJZtFGN6W6mFmopm2GEf3sYaR6wq_zw0vEJoZR1M7Ca8r5nHKwZHYSha92SXrNYN4B1xm_oOCoOEdCe5LMuGbkVNP6GCNKw8LYOf0smgz8vx5duS1mOwnyzMc
Cutting the pieces:
y3m7PmyA8ETz4WFglHh_wDDLSr39-1SAS1c6TvFMtLxDw0EuSA3YgYls6LDaCFz0Tc3YBJjW6Vn7I5DG2KbsNre-Zc6IAVslMb3vjOqe_STlX7tmP7gAuU3D2j39tplZv4uepjaNStUhDwR-4kAo64Us9TEdHaX6W43eTF6BHLw7rc
y3mi-YtNQDc21GqIXUvJM6hkV-3AROrfswZAAirwXve5uipoMXJNEygWQ4L4KcqBplFvZIagU3UElOj6cKpmRf8r6rVPBpP2ajr_lJwuLgEVhagypm1B6F1CVIDU4Yo5gxDdB-WnI4suLz8taPBBqHwRBtlDr6uqCY5zJPknbgAZwY
Made me a little helper to bend the aluminum
y3m97E6H58gfXbILMROvTzgK1ts-dJFua-AR5-1B-At9rNFcVoNEgfsgN1ytr5hLqv4f9RoasnGYs3WYv2hisJO3u1sdYtFUBw7TVHdfdLi8qBpXdc497CTjtb2g2YvmwHYOiS553NQp2IT4aYr6yCRYrgvvoTOBmoudHZZx2XrDKA
y3mQyo3EviTxduY4mSNyfy4vOEkH6tVEHxBLzpDOiycyUz5zoD2h_q_r5jMswBB-IG0eqj-Bd585-1fMvvnZAQxNW2lGP_Y_np18gX69U-0EEKGIh9QiiLE_8mFEWlzj58Z5Usv-aoSDb2TDv6EYi3r6CQ2AVAqABL7M5J4VgiI83w
y3miVjEP0vy0cCH6vxIExYg4Qbw05PP5NyPGcnS9Bbi1SW2UgPP7WEi2mdGevAa9dsIpt38kdJFxiuuPakUNcsAlWv-VrPfkVP9VkJgN6h4a2WYiuNHAnIURB5QiHppUGRiOA-ZrY0oD_NquoNpXkIl_uaEcqbKMzkLKkbpACPtJlk
y3mfe9qhQ8zlW8EfBzS5AaNtxNZBnot9PwvjaoCxi8zeCfe50XfK8psSDW7MvO5CELBBAqDwH4_5qbmPviKZBPMAd4v9t2wP3gAz74axN8bt1m-ecbdha6D4I7sezruHisr_IdEoVrzpZ8Q_jG64tEoeIwenv86FSSeze81gsB_B0s
y3mOrQ_an8Fj4hZYdx3HxLDfnbB_KxpSidmGKWNuaCvvU2Hme07FaW8Sax2_PHMRZDxotImT1oWtpX_CEnQ25-zuBtk1VVIWhmVsDyXwXBZZMPBPy_GRD2YT2jNnnv-zmNbqgoM9qP1UcWxJ47Y5EkzVGHp6FolIOMOvqKp-oC4BAo
y3mUzPPlhPqWyhzPEdJ6mww7pVIq2PzPRmVkZM8TmsQUYC5s5cNdyf2pF7L_t2invh5EhhmmfK1ImXWzqn9RcNVYjs5n9X-qnXLb9h__-Ej7uucN7ii1KT1yUo-pyRiGYb_1xcSbBCnEuVzZ5QRP5jqV7V12AGQjMThuwh5Y3oSPr4
y3mcTfsPKYN4pee2n8yr3L_3JCZ7pxfTP-GeRSGd5z8ERv0zH_hV2ly9rZtSUsYmM02qljrhbuY5CA6I6VQtMxhb2VrBKV9ARYjFP8WYCVObzto7HM8oaJgMFcRWCGFl6QHUTtVOUwkjchzQyOi9j9Uq5EKW11oaQenEnAKjN5cGNY
y3m7xTLafk4XkFoKl7dOUI3Ygb2qdMH8R0QU4uBMfmtRYAaoTGHeUhC88Fa19Ub2_OSa2kr6Usmt_VwqwuMAqwpNQQWwsYrtuscq9pPeQIiSCAPtuMxXfwascFOeTnSPobjXlpLzmelgE07CHPTlDY8wg7uKl2SujNxeSi3aCkVY_M
y3mzhNYrizc6IZe0hmTiCjbjmmXRJXJIXHabD-MsEow1uwddQ8ySdm1rZgi80afbq9o2kO4imuvn_ZfA9i_7vhjWCsGBV_AR4yz0y-V3qWPHPa7_0bZZJM2d8G-0Hni5uVzO8wlN5fvwmSNz4EKl4yPcHZi7b8anuDw4CbYYai5314
This was a heat test of cellular rubber (which i later use as a vibration damper)
y3mqK6G8Aiwf25fEyNAlO8T8BOUl34quby9YVQuutRnfwL1goMYf67Dmvdb2YfEZg9_aNAOXnC9FhZUaCd9sYThI1-pTzyTSJGNDdEpt-fJp-K2vH2BRa1iWIwydAznrwDCH5FHG_PF5qHL9MeixMKIDj7mQHEe8m0NgVnROHRr4Xg
it has passed =)
preparing for bending.
y3mMismayUEOziDsZdYsef2iW8jyUkkc7QWkJ6KGBsBUEolpPxXE1cwuPr-VUQ5XBT72OIaODPx-KfKugaYC90uxjJG-2j-Sj6jQBHN8NvU33Yqf3hRQPbVPO1dhinTJFObvvyVjuZ19W6Pvf77uZ1mbFirEDVcrck3-2UqBYjNuiA
y3mwkLxC2UIvxJV-y0W0cL5WEqdpXW0yrcN2cKvrtMMxWQp9uFa2r_Axh-s90ktJegtf9giSbQQoJsM0B-yxK7ByxRDnMzrczYzhZZ3u2YrVm4ltmzgjX0ml3p9S2PDwyYMyLO01GODm1VTIoNgdjtqsSWqbp3G7s-Jp_1rM1sVfrY
y3mVD3tZ3qwJyQnrmMsRE1yTNndCauCknroRg1gd8odRdC7Xea_LIlSzNjY5sZDk1poq8NsU6dVo2eRo8MG-tJsfJkBMoHU7RFWLJVMFPMv-rgo1KEhxKv-L7F7zPlbAcKIh7aVeu_FBC1PkXlZBhjEtyMYqmRAAyqyezVZYr1elOI
see it works fine
y3mzT72UbI2SVZxrsFaxvZl29btkgNcXpoy5xOh_FZNCR7DTBomVNAqD-PXqXjL3hT7t8Fu_nv8Ho1GPU7e7LMu2OhqnUKwaLQCLtW2KBQSqm0SWJm5KTwEQL0etsx_-1SfrTqJDf8oukfiEAzNmtYIt3d1l_9xebbejCtVcknDqT0
y3mGfwEAd74UJvt5YfR7SHpQzLnns9akiIOSlfjAJdWw8fJNBCfaiVKRiU3kLtAjX9Jveknw6O292bzr6wvUeA2va0sqj2VXo8zmLhV3HByGtlzX8jGU1HVi9uiPiLcnQVnhpfCynjq3QYaHEfNtEy1iUZ8WjuJbkGCgby5nHgujd4
y3mey0qV79jEgZeWJ_S7llBJ0_n67QO_Jy-dBZm9zXGwfFkx58Rx8yjurYduC5mm395lizjZ1XWsaT-a0UY09jJ7E_MVPZsJhCv0SOD1oYs6C4yGJRuHZ7VenhQr1BcJWQPxZfcgjV-0nWl62hwLgVPMB4pJKeLI5lW0sm2lGGa1DY
y3mTSRHLwMiuDXuu_0OSTyrjZj0x5glLaRWTPPY3OCqXKnQSa5VDIZCmsoDyySQm2NhNRYZVZbFtTEX7jNKGktSij6HK09wbrMmEWlknDEJ7N_LyG7-y-1qIeBHxDEWhOySIilQXbygnm9HTl1YP9UaIdpbsj2lhmP3PmtTP-YqAp4
y3mXcg1Rwxl4W8z8mbMe07IFz9anNNeNEOa4YazusAOSe-EazWQMfe1rXf5gXjIPNj4F2T6jsko0scczsgCIPr66R6ONlDu-UYSkmjLg1oxc42GDmD0Ka2EIYPrjMzTtPWk2FqI8YKUGmdu9Q39eU0rnHXOVMr0qoANu6jZy1_HLgY
y3mJd4K2v6Sl_GY8ZDHdGqU9hRIsfU-YTJ3z_lF6FTfiqPDUqodEhtIvC3BZsBgS5IBjg6SHB0CHUnEC5XfTOOQxSsRmrCxx2UragT87qjNR671mX2y35_iVxOkpCncQkkhN9wjdV8BWmhrtBrofBXelBPdgzkyoAlf2XnITebKo6U
y3m80KixNaKdFW4g1fe5EqXzViLZuPDMUfVqr3Fl4obvAlN9nABA7FbzC5cGAP33wpSdsuQogCGTqHOYjnt4ygVmUvy-hZO5POHflPhmkXMeLXD4sZ4MVKdoFIPNdvbc5LxHA_P1oxFOqscBaZCHQm_8o5Y4k1vFWHx47d0-KplhfE
of course i did the other side too
y3mwdzkSITg93nwEv9c-cxvH-UnShBEbOya-Lq_x6JjsFAWfPZquJobtZFe3s_GxbUVpqJ8iNDj1qjpr3MtPGNiHD2nMx03J9fJwOxLy21sM0cotOwVo73aQMy6CX_PMeiJJL-tvrr219ZW5NosKkP9rorB8Wr1ekcZLi8VHdeLOTc
y3msBbw6gkOqfwX6jEeoeNijXzSEhI1t9YwTq8u0DBNKDER4f-t6_O7NgcmvsHgOKiUYHS2G1RBh74-1t7cxhNf9huCrMBIcrSkuxoS_ipjZ5mjLErzcVtgtSHUbp5RDtx9slQBXn3appvtdTLDjgbzi5uTIHzexXtLmzUmdhbUVXU
y3mE0HYXHk2VmwGjnQR4WafD55IiKfy_qgnbT2bb4p04dEQatKZ9HisFuWfuYi_3msMqR4GfN6MbeyzfJAXJg7uHBnbVWupmthQrvitXokJI84xu6m-8EfmPx6ZgKrVdSxgTHxt8gcnzpFu8DSH5p4szfZlvIgEf9FqjOi9fxW_fjE
y3m1IGs1vZ_vy5JFZf3k-0uPHeNmOVE9YZkQA3-ndR3eUhbG996TodQaHbv76EWokPq-fFVOqBBFt78x5oEYi7bYwANf4wtBepYCUK7QUi78a7aiaIiV2_42J-6Z416WyHUiq4fUomtkbeNQDqu19eNwIxc-xjd4wKX_Pgk0IJ-aNw
y3m0ZK22Y9kpIkgBvqSsMnHO0Ko5NEJeaBBteR6VjOxI4UjoN93aAn5nVOpKGlNfOcgABW1hTcohK4EFwGEUzmWA28tJnduaDj84aadmT3akaBcfQhMH0rXhZFHH4c-hK6xJqeKhYpwZ1qA4ecCb2KPHET0-aUaemfFLln-z_1R61Y
Sorry for the the quality of the last couple of pictures, dont know what went wrong with my camera.
Silver_Pharaoh
That's looking really good benny! :thup:
That case will look sweet with some LEDs inside. It'll look good with the dark plexiglass.
That rubber looks familar too.....
Tymofar
Tymofar
Thank you!
yep i hope it will come out as i imagined it.
If the lights and the pc are off u cant barely see something whats in it.
Then if you turn the pc on u can see the individual illuminated components through the glass but not all of it.
And then you can turn on the leds to see all. (and its dimmable)
This is my imagination.
Tymofar
Tymofar
so...bending the Dibond
y3mT5fNMpjkxRHy-HCUXCM2xKG3qYLVKH3gNL6zVxzAdqnmTpinliX2s470O0vg5Qmx5OlLWPY4FQpYE8bK0ZbkC2slBJ5WcTSdum4DuOcsaAydILrS6byVTt46Ehcw51UO6Kaww8LrGZ2XopvGx3Z-B5WJxy1j46wrWjNf5a3zWSs
y3miD_fplGjT_Rk98pmx5Zq5wZ-g13Uot0yD8SzMy8Xb8JeHsU1qDJisOQ7144-Z7Fakw9f7Ocrzb1eDu590ndPKfTeZra2aLHxg4q1qrwc629YOttDWCSeY0Q2j2gX6HIifed0VXNpQNlO8INjc7vDqo6y9DaTW2ETfnjgoGU_u6s
y3m1D-DlhFOAKJ6RVDHk_n9owcOfRgW3Q4LHp5IouC4X1Y_y5jaWXAi8urce9D4jtWo4N0NiSC0ww4Bhbz2fxUP6Wn1yKjF5H4IwBeAeO81zUsUlWMB90SzM46suzhcBegisNAftZ-LwH2YQB5u8kN-8bhSWoQtOZqkL_dhBqv9EmA
y3mB2L8jXRlwz64gjw8k2tDyQyXVGUJ_cJ893nhrB4Nk8KBAmWZPeDHdjNYtJiE4y8WRUANqUFUF_iQ3zihHBvyJ18Uyp5Xo1W8-YQBJ3Y_9MKyRbiFZMAzOFq-ydwYfx6VM0a1OtSG-keMAwtyIWrKUjoAXpBxn-f3NLMDkwEMRx4
y3mShwfNrjKveaQs_2O_OETctcGV7niUtVYtkmYXPT1iOZSKIs5TaDwsc2lUEYB65fczwupZu-lzFuStuIMD84XK1pPZjxARHddCtF-wPDJQmLmvjJfW3UL8X1cwXpDcMsBUFS3Dxq8RdtOh8nmbh0MXGrOY49Te8CQ_BfX0m7TadM
y3mqNVSLV0AgfpWhp8Qsqka-XB8iozPRepQ6QGmRdESRaz546tjqX6F0kD-u_FF_Y9hIDFFlVMn7Qmdyo92F29vTzaY-8MSTbQ4rzimUmKuahK32xOVjQgKEv_e-oDK8_XI_DtvlIC3xBQ7vZEmG4Ih6m1GDu7WyltxD3oWHgHmaeo
y3mM4rvkErJPR7aPhvH88plf0LZ7tPFZyb238DxTwNeyIDsbpyLDs4O1fKNIrIIgRvYxYzr9FtO-DZ3lBLaycw7FpuJjghDRkoLynWUY4avNqEUJkFecFAhCJ7VE7zZSujvfIGgLm6VVrOrL1z5JhGckm1g_iED9ErsZGRuqJRF1tY
I failed hard at bending the other side... :(
so i will use it for another part.
Now i have to wait for the new one to be delivered.
y3mnm1y80mK4SSCFGFND4CWJApdGbX2IaLbKvDrhuB0TzjK4ppmfKq86EbO8iLyqRQOJSTWDTrARi77fSFTTz_NqOb9ToCDChXhLNbNpAVv7lT-r_CHScxSkkSDcOwd4Bp0et54fYFweLqMgdc7kbEv0yvVAj_P2YrWfqWY01EvTRo
y3mgQd-5ubnWuVaAV4GGhJOWI9hKdxGXmz6ykMsIulm6Ek9LS28ZWmad3EJ-wDV_TEBT95-5QkwrzK9b9lnB-cFZmiYu7ySX8RIKOlM4oLsMuxuM_iWs58b2WUtG2P6ZBYanOGHcqrhPeUaZzwppapPxbFPfKf0uXKA5y-0XTXR4fU
because that pissed me of i made something else in the meantime.
drilling holes for one of the top parts
y3mpax92ta3jyNrEEqWpGKIkrIR3kS2n8gRqe0o-gvdhxDuuLiTwErLoLlKpkTe7B6OCSFF-i6fAAFSVg4UYTVIhicy1kOmuKnhU78ToGBnTSSGwDKo0MfsqCpGubp2TAi9w1yxl3mPJZ_MkFizRiBniOVAfjxXfDS4ClYPtZfMjoc
y3mi-Cw3wHt8TAquOK5Qnnb4g1YeF1jOmhvwPMgzZCubRzvtmnrLIN_9eeCDH4yizXeQQQUN-FID2GntM1X1cS_w1D9qItdEEidXNE1H1hf_CRzV2nVJc3iUhuQLFpIxBpeSJCxli6hyUlJxAfxPR15D_TaCQ6pYzLSyuLS6ysQcmk
y3mgaJvILEQkK251bbT40-L_bCYSg63RALaXMACzK--IbNGjxF0q9olrYBr2R2QUTfThcuKKygscPOg-OEVUb3OonuZ17A_2N8oWoK26sY9CrbiYeEzRROcBcS_MYxTwpxIKhJWa7OcoqVrrUfi9TJgLQB-JPNkGNQGPERof0dsWSQ
back to the other ones.
y3m121au0SMjGbSlw9aUDMW6XODom-Olpw257CARYLegcm84iScFjSNQGoRa5dtwLu-i50I35BQXju6P84DjtCfHHSmL9j12hfFAT4JWRMZoHjTtaJODc4v5SxZkE2m6WKY5T3EMOl7MeXyuY1ojYe1cng0Yh7GaTlQOUke3KZuAiY
y3mC0GKMl0CR9sjpsmyqjckEHnf30nPEG6SqLa9QpxlGFcjmgYCAgKq4KSf3jZS45uSC8Mo8dHfAab67-UFi28iaXSfobB_vZDMWgX2UUk3tv11NmiQKpCxwYi6zr7GLeQSVzcJQ3doL464oRtNjpazHfe9NFdedYUDBYrQt8xAzEw
y3mIEQUzWEeTVK64K6WeOALbBz6E61tqCW7wQU5NbsFdBy9CXSyPEPdnD_1JALCinSj42BsHCOsrfJQ27ypSIxHEV-sxO28Zr8YZLCcyEpjqfWnvi32UEd3siMb8tNHaYPrA3rcL1XAJ03yPvAv73IRKcfDW9qxM66szXoB498naEc
y3mJ7Diz1RV1AkbK5u3ntwQX4Bd9DNy7fFS1ahGuSftKVR2rkWERjWlzusMFjdynJJYfuMSf4pcaqR8lVT10RJiDPa5VNh06NpX8zeOqA8MsAxq6IVZSvpoqmYtSPylVRczI7c3N9zof31r12hd34k9KbmQ39Aw24xIRYzQmybY_Bs
y3mMlC38WbmBHecP_qzN13EYZdGBFpEzBbNqhYceSk3F2WDKekxTzmixb3vIuNwxJlh7gck03Pp2fE2rfZeAESwUk67g3hQlxTBHWh5e4Xn8ocIubkasEppYSvaY16oi5fHCTLsh42Hxyk6rHKeKIH7HuDrqI_ggFFbBjOB0RGbbB0
greez benny
Tymofar
Tymofar
Hey guys,
got some progress =)
my plexiglass and the new Dibond arrived.
y3meWchODQk0SVLCM8yaf4x1s9RbjMCAdqIqbXTONk5ooYOZhXT7xHm7GBIrLCvMnxqeAUWF5cCPZ0nJxqDa4Ew175KVoXeAeoZYWhaUGKNPcuM4oSZHSjLASnesmbLlUi4DmH9vFE-vIT6p3WzhiakETBVsBT5mfP2hCsqIpWwO-4
y3mMOaWOSk1Z-S_lm2LbfkYMQg6UJ1GBS0zs1gJ1UpAnNjZBdZoxLHLXQCL-7CkVAEJ81xuxWQguNECMEIR8xnKc2TO5r9TDfRL7ACfKKO45UV0NlZDUSVxiV3D8Z3pjf-f7mHdOANynfG46yhi2yvHY67m2m__Ks-N8zK7b0IaCZE
The cut outs for the bottom plate (black LED-plexiglass)
y3mitdCHfxcAhypFsHc0KLIm2HWswlkVBA9PLt8YRHlVk-Vsi7KxzV_VNl32QfX6Pcv_tqsGyv3-llTAedyKTXM5qI1b_aLIJPrjh5Lv4h0y_21TiFmb_6_2dz5MULa6SO4-4hW6cIgzVbeOzxaxSCYGAhl_okt-a1TxqsZELemq58
y3mbQcoeCWJ-sBPKcH4R0QoL6NSaSVUHG4fAHtRdU0VEISOLQPQIJURuIQeB3bTz2S4Zs1gEpF81ZGK33fww10tRUcDsK1YmoUpJ7haZ1Wn3GxgyynDNgYmG-SWxbiqjZyN0GLZxlDaC9xonujNgTpeVcvNpTs4QGzNeS4YJoPRAvI
y3mPr3LGJ75VYKUyr5LdWcCYDee6y6yB6Bogf_Qce8UncRZNDRmNzpAoaiA_mCu-l3c98g0SPnE5QDtzN71vskYtIdqKdckedL_XF36-x_TAj4k6EosT1X7EOzJLkBKw5sYvyxlxiLXTRLVZYVyP2ubCj7s2pUlPerWXl91iGD305s
drilling the holes
y3mgP4Nl-J0xCkV3yGl0AYNsokT5I9u7u5BIVdP1vo58K002ER4cWmAZb_f2SflAcK750oEiuQjWtyxcmOnK0cntnzXX5PZKhOcNxyHmPV1BHfLgdGZve7apdEvlvKYTGREOFRlzp6p0lh-q5axNdgo2QwiGy3whvUujh5HToovPM0
y3m9v-_T0LXIdzIO6hUemA2VOINfgDe2cmLdCsis15Y2iXCdZOOhrQ9zvqZRq9aEbeI2N4UR0O4PMm0xf88T_ke5R88TS62gOKXcoL2Jaj4d5Lzy_5faSswXq4qqaLI4NfDOm0Z5HxfP3nM4h9NG1kQK8-I0xKuTqW3mw8wRSALNbc
y3m1YCg19H_obaqmZ9XJcdewU-XsP04nGz8p2NMXd-JEh4JuF2nPV0UOLBo9qqHO6LQqbWSAfRT69BwDuol3YqPQkpKqXThDZuG5pCXUmvrwXFaqN-s_lzxNLC9_q5ulrvrFUd4AJzD7g4U7S7d8Bj6nJMksGtON840Xb8HTCUq-1c
template for the rad and the fans
y3ma6tDY9RzQxbxDrv6ZKrSlyVdXyA6zw22tclTMw7oQJhVaN9Dx1y7jfkRYjcwN1kjgb1urgyOhE0-z7RVbtPTduU7GpXTlp2MXgY5TMVM7mQapMhd7J06tvt_VxmG_E_8bIk0XNGwkxL6GzorMR--AAsyvTyEP_gS5wjYNWbV60Y
making the holes for the fans into the top part
y3maQc8qLnk7Xv_oLt0FMZGB8Z4MItVHq9Cr_C4-6HmxmUc8zBz6t7SK_9hgqVwFVBvlBPLNLKI-TAh4gZ8mzHgI05gnzqMmL-nPAse5whFH0tsLazo5RdcpFj3vusWPWJAg-jwGvtUzXAUKp2Pxq6hxNadQXrnEvRvOMLYEscydj8
y3mEKEfgvB4jwH3hcL9M78u2ftLOwWo6-fJwif438DjDwTs64dqjfCFrecOI3K0VUljbThkQFAMuK-X5HTny9LWs2kPNteB1PpObXMoO-WrFS3jrDsnsIf-SBPZma6bPUX4xjfY7MSIjr8l9kFIqroZDB_D9hu0Nxkzmw8GQ2EohpM
y3m72rvoMUcnOD4LzHAgfymPQrc-Sz7R7VEOrwpTB3a9eyiOROY3Z3njLFL3CsVxG4dy3QbLgTQKzXww0IZtKEQvbqAjDQYCajS9LrhH-I0_wMv2mPR51ftlcU-zfWVWQDlOVDxouw_NL4o6XfIFaWNJ46P0pIIX39_XueiigA0v9M
y3m1PxgdB2uKPoUm-w4vcXw3o_I3izbXWgimqI27bShmg2q3diVJWgYJAJDl0aixJ7IM6S6s6mJWnq0tWzqx-pqB-qsMYC1y1RnOgLHPmv4Bzu48T2LazK7xN3IBJ9vOG7DUMicg16ZTx5BfsU6Yz1VKi1oSwRUePtNt8gXueT71o8
y3mlbBn6FxGp_05U03k6ZFNbrPO-FELJ5yI0e2ABSFTPOaHh9nrZWvcAIcOBjClz1dhh2C-5QkHDaTALhlS5AvbZq0C-e4PM2EpfcQWzGbUlbe7cXKc3Pl4DzVjUxbkmdKFsH5zAYLUgi_vpsrSMWabcJg2mQlFCPixKErUoqmuOOg
y3mrfKZUEwGXOJOZ7fc_RViItD2nfP3u_wICpU8lYWpQAMfz0ktaOfr9n_A8ENf2JSROZxLpxTMiMwOMLWQZoYJnMl3Ugygy-ZmtkcUwv9VbqD0bQCA0TjPobuKFyGu9aj3IlqWAZGnnTR-CANqNDalFwnSLR92CCbD0Af3MtbZeSs
so next try to bend the Dibond from the other side ;D
y3mYqhaQn0qy_9D2JR5nuC9dIcEzHz4_4t_0ta1brTC_QWY3y2t21I-ka6oVFe3s334JUTzYqJ9_rfyX4Z85y2DsHUvVemhL19FeQ_FHDtM_wtAl97Wq6GJEPK_539_7MiMqdDgdsq4q-Tt15TiuJLcUOPbdHmMrQ4dNqcaPaA2Hbc
y3m1YseKw_1az2SozcQ4ZgMEm4uytv_vHebApVBC-grf9xQfaFhqh_5cilzcjPhUxSoNdLIXDP5X88tG0ZhvDb-Un5jt-zbjYu1CpyAsts0iDxclcSdNhU3m9J-YSyHoYUnrmr_X1JQznJz_ZEWuLAwgMNRiT3eHmLSt08rflKiF2s
y3m8DkWCqqx8wPsNpMMbx2hSwOsk-iXNjX54gzeNKcdX-7IYsFHhqd6krRTdlqdoSZwol9cD_kjvkFzph_A0s-gu7R4EoringdAikapd7XmTKqWQB6uWH52uCV4qLUQNAI_ZpD2AtTQoKTq_WILmArZtdgs5nvYsJ3aAq9ViC6iUXw
y3mxRnO1jzf6gYBzkjrl11M_wq7guJy_7Py3mBz4_PtgiHdQiMf-04gsuz9LDwB5Mn5DF2SInKqG78HQJrgf6qwkfHbJV-mqN14xSojZwTq3nIWmsOZtwZ-TnXkPEf07C_E6EgEaQvhiqZgJYnv6s2yhWWLFaemDcVAw6ViKuIYPzk
worked fine this time =)
y3meotU2VaKPwsaqOafjImmD5TUBImhcAIJUd5reJgs4QV7At_iytUKnA5hIjkLKGF2cg89nPVNlSulOFDxhlT9Av-Yjh_SI4NI32Z9udw8D3QRaKS7PYXgh9kq90IQi9mU1SwySVHdEIKBf_zADMRQG952_gSiog8HQVyzFtDw7sE
now cut the side in shape
y3mt2wW-0vO2z_Uc0EwWAIWQU8dcwf0Q5Jg_AbKkhfwadctKZFwfs4Y_UbXxGEPfH0Zptb6_ceFNViKwSobpFtmumW-6v-ZyG92_osWmuCqthWFTPvv1-QxZlZiITk_edqvGWfZGxr9ofpIhtlJ0NS8fkZwq88pvullol4cuhCV6LU
y3mJ5q8rAlrX80LTyg_gmNtwVZq7PV0a1AYITmyVtoPnPsIluCRjoVJzYY0voE4-6K0qW2SyGEPjBA7N9tYDJb8ucR7ZSMam4XkwDXCJmyMKHZU4Eag1qpvZlgufGJaxW5PlTLH9V0QTx2QEL6UjE4oiS13j2FYmfxGUiYQfK63HNw
y3mt6QgGT1y4VTRw8DXgip62j2DK0xGOtm_wuHwEecRYwO_FCO1O1sblYMy6aORuqLPFwEm5coj4YP6zM1frPzJg5Re4D8CuayammxN1Uw-hBMVRzxSdfBu4qwuZJACzIyBV8jk_zi2_sFHoxVCqHQwE6z2xy064yFCVD7D8DwCDSg
y3mBshOTzCm5rPlH5jHlpV7l0Q09f4b26hUWy01cLqaTyzfznJ2dSSsMtKG_LRPFzTbaWCX65EgHQ5OQ5CW2OAEKtgqpRK1xUp9FUTHn04XhLYi8FCX1wdtorqog_QXNNS-L1l3mWme99_k9ekWkisPuc_h3-1zCu3L6n0T4GXc9V0
this will become the motherboard tray
y3mZQUfawemA5DDEyj9inA9QHOMWnCbEEOyBllUWvXwvlKdbZSZar0ot0zli0zLfgFp8L742X3YbRWHgFBbsgUQfk85TkqJFb4z8qbW96fAj353TuNzC1fSPrm3lfW_QSLW1EVEx1-XN1Xn4YTlDwkVbwBMZ34_OsMDKQD3wkS3CGY
y3m_9kblPUzUXzgvZW9aTrxP48l7AEyNKBQt1CwtJvTlLk6A1ya60sTeQmXxNcfafH2RVrHpt6LSzG2FCHiRLI4GL9TkSoTZTfCkCMJDYZPP1m-7se24edWU1dKX_h4BjD6f0l-fBkP-fis2e9SLrJnffoIkSqF6BWK4rE_PzegAtM
y3muMURRAszTgblhsgSUQp1HVOYSoQthFS5mGYqThcO6j4scrxVsMYS848ZzVtohpxd6g5pem1Y7k5nj28kEzJaaF1FbULnbJxYLIm5JtytC14Ly_s8sRGJF2nf4HAom3VDs9a4WKUwCxh6_sRZJyvNPSJ4ciU3AifYKxJJPOTYVfk
i hope u liked it so far.
greez benny
