dark_15 said:I owuld also suggest going to a Brand Name company, but if you must DIY, then take a look at my similar issue like this in the past. Here it is.
Personally, I would go looking for a barebones system. Supermicro makes excellent SuperServer Systems that would probably suit you nicely. Go to www.supermicro.com for more information. Since you do not have some sort of rackspace, look at their 4U rackmount/tower boxes. Get a box that has Redundant Power supplies; this way if one PS dies it does not take down your whole server. And yes, they are all intel boxen, so this will be a Xeon - only crowd.
Go with some SCSI drives in a RAID-5 Configuration. That will keep your data safer should a hard drive fails. Supermicro Servers also have an option to install a hardware RAID card for better RAID performance. I strongly suggest you purchase one of these as well. Add a tape backup system depending on how much you need to backup and how fast it needs to be done.
And definitely split up those jobs. You will want one server to do email/AV/whatnot and let the other be used as you PDC and accounting software for security's sake. If you cannot, try looking into Windows SBS 2003 Standard edition. That will provide all you need to get started and should be perfect for a small business like yours.
Jon said:Why not buy or lease something like a Dell PowerEdge? They have systems that would definately fit your needs along with good pricing plans. Support is good - it's where Dell makes their money.
Jon said:Does this server absolutely need 2 CPUs? If it's only being used for light web/file serving, I really don't see the purpose for two other than adding extra cost.
