Proposal for a new server for my employer. Need advice.
for the future, talk the firm into cyceling computers in 1/3 (what we do at our 100+ person firm) talk to dell, hp, ibm, etc and get quotes for the 30 ish workstations and servers etc. order just once a year and you'll pay less for the hardware then you could build it for.
Dell allways wants to win and maintain their share in the market so they will bid low, I mean way low.
for instance this years bid,
dell 109k
hp 146k
IBM 155k
We also asked other companies but they didn't respond.
They also gave us a free upgrade to dell "gold" support and for 3 years.
Prices per the dell website would have taken the total to above 200k
2-bits...or looking back...mb 256-mbits...
I would go with a name brand as well...But especially if you want their support. I have around 140 stand alones and 4 servers at my location and i'm the ONLY tech. Dell service has been great. I have (i think) 4 hr support on the 2/4 servers (2 are out of warrenty), and when i have a problem...they're here. If you're within 2 hours of a major city, you won't ever have to worry about waiting a month for a dell rep to show up. I've also been through their joke of a certification program, and that gets you through a lot of the red tape on ordering parts. You just tell them what you've done and what you need. Dependant on your warrenty, you get that part in that amount of time (2hr, 4hr, 8hr, 2 day, 5 day... or whatever is available now). It may seem like a lot to get something like 4hr response time...but when your buisness lives by it's ability to send and receive information via that server...that is definately the way to go. And for you, that warrenty does not take away from your ability to get that tech job...You still do the troubleshooting (unless you don't want to), you can even set up the work so that when you have issues (on a 4hr response time), you can do the actual work...
Also...Having a dual cpu for exchange is much better in terms of response time if you're getting heavy usage, which it sounds like you will. If your people are anything like most people, they'll have outlook open and they'll be logged in to it, while doing everything else. Which means everyone who is logged in to Exchange will receive whatever updates you have set to run every x minutes/seconds, in addition to the other programs being served.
I would disagree with using 2x36gb...Email is the largest waste of hd space known to me in a corporate situation(with the exception of major players in the cad industry...and i'm sure there are other exceptions...). I would be worried about running out of space in the first year...I personally would go with a raid 5 solution with hotswapping equipment. Start with 3 36gb, then upgrade from there when you run out of room inside the first year and a half. Four years ago with 50 people using our Exchange server we were always in trouble on space...the fact is...some people are not allowed to delete their email (which may be similar to your case...). (we had 5x18 7200s raid 5).
Anyway...So this "quick reply" thing...sorry...i'm still getting it down.
edit: Oh yea...and get a tape backup with a one month daily backup. You'll almost have to go with the 40/80gb dlt's... Those aren't cheap either... $50-80 per tape (certified only...), multiply that times 30 days (rotating 2-3 weeks of that off site)... a dlt tape drive runs between 800-1500 last i checked... (which has been a while...). Also, make sure you get a software package with it...i've had troubles in the past and currently trying to "make do"...
ok, so if you are building this dual xeon system, you are going to need a parts list...
case - CHENMING 901AD-BLACK-0 Black 1.0mm SECC ATX Full Tower Computer Case - Retail
power supply - FSP Group (Fortron Source) FSP550-60PLN EPS12V 550W Power Supply - Retail
monitor - use current?
keyboard - use current?
mouse - use current?
processors - 2 x Intel Xeon EM64T 2.8 Nocona 800MHz FSB Socket 604 Processor Model BX80546KG2800EA - Retail
motherboard - SUPERMICRO X6DAL-XG-O Dual Socket 603/604 Intel E7525 ATX Server Motherboard - Retail
operating system - depends on what you have/need
memory - 4 x Crucial 512MB 184-Pin DDR SDRAM DDR 333 (PC 2700) ECC Registered System Memory Model CT6472Y335 - OEM
video card - SAPPHIRE 586L Radeon X300SE 128MB DDR PCI Express x16 Video Card - Retail
audio - onboard
hd1 - Western Digital Raptor WD360GD 36.7GB 10,000 RPM Serial ATA150 Hard Drive - OEM
hd2 - Western Digital Raptor WD360GD 36.7GB 10,000 RPM Serial ATA150 Hard Drive - OEM
tape backup - iomega 32929 90GB Internal IDE/ATAPI Interface REV Drive - Retail
backup media - iomega 33043 35GB/90GB Rev 4 Pack PC Format Disk - Retail
floppy - SONY Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
dvd/rw - LITE-ON Black IDE DVD Burner Model SOHW-1693S Black - Retail
case fans - 3 x MASSCOOL FD08025S1M4 80mm Sleeve Case Cooling Fan - Retail
hsf - stock intel windtunnels
ok, i have a decent system picked out... should be more then enough. i didn't know how you wanted the system configured in terms of raid configuration, but the motherboard supports raid 0 and 1... raid 1 only gives you 36 gb storage total, you could always upgrade to the 74 gb raptors if that helps. i figured you could use the same keyboard, mouse, and monitor. those are mostly personal preference anyway.
in terms of the OS, i didn't know what OS you guys needed or what you had. i thought that it *may* be possible to transfer to OS to the new system to save a lot of money (if you need a server OS)
let me know what you think. anybody feel free to offer modifications to this...
here is the newegg link to the wishlist:
https://secure.newegg.com/NewVersio...&ID=1707580&WishListTitle=server+for+dwschoon
audio - onboard
Thanks for the advice. I took some of yours and made one of my own that has onboard video and ddr2.
list
