- Dec 21, 2008
Hello, I recently built a new system, and right now it is all on stock cooling. I was looking at new heat sinks and fans, and realized I could get water cooling for not a huge amount more money than good air cooling.
My setup is:
Enermax chakra case http://www.bigbruin.com/2006/chakra_1
Asus P5Q Pro
E8400 @ 3.4ghz (hoping to bump this up around 4ghz with better cooling)
Asus 4850 (I plan to add another in a couple months)
I also have a DVD drive, one hard-drive (I plan to add two more in the next couple weeks), and a fan controller
My planned watercooling setup would be:
Swiftech apogee
Swiftech MCW30 chipset block
Dangerden Maze 5 low profile gpu block(s)
Swiftech MCR220 Radiator/Res combo
And possibly a Black Ice Pro or Swiftech Mcr120 if required
MCP650/655
I have been reading up on radiators and found out that the only double length radiator that will fit in my case is the swiftech above. I plan to mount it in the top of my case with two highflow fans connected to my fan controller. I've heard some say that this is not enough radiator, so I measured and it appears I can just fit a single 120mm radiator on the back fan in my case. Would this radiator be necessary?
I was looking at a test of thermochill radiators (http://www.thermochill.com/PATesting/), and saw that the mcr220 is not that far behind the PA120.2. The second graph from the bottom is what I'm basing this off of.
It appears from looking at that graph that the mcr220 and a single 120mm radiator would put my system somewhere between a thermochil PA120.2 and a 120.3. Is this correct?
Also, I need to keep all of this inside of my case, otherwise I would mount a mcr320 externally, but I need to keep it all inside the case.
My setup is:
Asus P5Q Pro
Swiftech apogee
MCP650/655
