As if the bios issues weren't enough, there's another potential issue here with the AM3/4 cooler compatibility, or something. I would never have known if I hadn't overheard a guy at Microcenter talking about the problem.
What happened:
I installed an old Hyper 212 Evo air cooler to test my new Crosshair VI and 1800X out. Booted up fine.
Uninstalled and put in the watercooling loop with an EK Supremacy Evo I had from a previous build. I don't have the AM4 mount, but that block came with an AM3 mount which is allegedly compatible with the CH6. It does fit. Leak tested for a day, then wired things up. Motherboard LEDs and the "CPU ready" little green light are on. Push start. Nothing happens. Not even the start of the POST process. Recheck connections like eighteen times. Nothing. Then I remember that conversation.
So I loosen up the supremacy mounting mechanism a bit. Still nothing. Loosen the screws all the way out, so the block is just resting on top of the CPU. Now it powers up! I shut it back down and tighten the mounts back down very slightly. Now I get nothing again.
I ordered the AM4 mounting plate from Amazon which hopefully avoids this issue.
Any thoughts on what exactly might be triggering this?
What happened:
