Hope the voltage was better than the recent post in this thread- confusing times!Maybe not relevant for too many, but Phoronix tested the new microcode across a number of benchmarks, here. Overall, the difference was -1.1% in performance, though the individual tests varied from slightly faster to as much as 11.8% slower.
Is there SW that runs in the background to monitor voltages while gaming? I can’t imagine there isn’t by now. I haven’t updated yet so I’d be curious to see what before and after is like.Ooof. Sorry that happened man. Sounds like your board crapped out.... doesn't seem like a CPU issue if it's working in other boards though... weird.
FYI, I installed the BIOS update..........problem is, I never benchmarked anything before so I have no idea about performance before and after on my daily driver. I'm buried in reviews trying to get cleaned up before the new releases...
lol, would ya stop already? You'll be ok!Thank god I saved my old rig from 2010 in case this one goes under. I can’t afford to be without a computer currently.
Yes, don't sweat it (can't, really)...Any TLDR? I had my AORUS Z790 + 14900k on PL1&2 @ 253W since launch, haven't had any issues other than thermal throttle under full load benchmarks. I see on Gigabyte website BIOS F12d with "Update microcode 0x129 to address sporadic Vcore elevation behavior announced by Intel". Should I flash?
Will seeHwinfo64 is what I use...
lol, would ya stop already? You'll be ok!![]()
I just said, Hwinfo64.What SW can one use to monitor voltages for the inexperienced that is free?
Thanks a lot!I just said, Hwinfo64.
Free Download HWiNFO Sofware | Installer & Portable for Windows, DOS
Start to analyze your hardware right now! HWiNFO has available as an Installer and Portable version for Windows (32/64-bit) and Portable version for DOS.www.hwinfo.com
That chip doesn't throttle until 100C. The difference you see in scores is within run variance.My 280mm cooler is unable to prevent long-term thermal throttle, and temps peaked at the 90s.
Here is my report from trying the new microcode with 14900k. So far looks good.
Flashed BIOS 12d from Gigabyte website for my AORUS Z790 Elite DDR4.
As before, the BIOS update invalidated my Win11 PIN login. Have to be careful with this because if this happens when you don't have internet access, your windows can be permanently bricked. But with internet access I was able to log into my Microsoft account and set up a new pin.
First thing I did was set up my old RAM OC (w/o XMP). Was able to achieve 4000C16 Gear 1 without problems.
Next I tested R23, score was 37k, which is lower than what I achieved with the F10 BIOS.
Then I went into BIOS, and changed the following:
CPU Loadline Calibration -> High
IA AC Loadline -> 55
IA DC Loadline -> 55
Vcore Voltage Mode -> Adaptive
Internal CPU Vcore Offset -> -0.125V
With this configuration, I tested 30 minutes R23 loop. It rendered 93 scenes in this time period, with a score of 40699. My 280mm cooler is unable to prevent long-term thermal throttle, and temps peaked at the 90s. Single run score is 41015 with peak temps of 80s. HWInfo reports a maximum VID of 1.329V.
I will report long-term stability with this BIOS and configuration. I think the undervolt is too aggressive, but we will see.
Not exactly. I only added loadline calibration and negative voltage offset. The power and current limits are still in place. The reason my score increased is actually because of an undervolt.FYI, by doing manual voltage adjustments, I’m pretty sure the voltage protection of the new micro code is disabled. So you are basically making the update pointless. You have to use the Intel default settings to actually benefit from the updated micro code.
Did you revert back to previous BIOS?I updated the ASUS APEX Z790 with the latest BIOS 2503 with 0x129 microcode, and I get random black screens while posting at any settings. It also crashes with RAM at settings that were stable on older BIOS versions.
This has been happening to me a lot even before the BIOS update. Instead of a BIOS post screen, I would get a black screen, and the GPU LED on the motherboard would turn on, but after a minute it will show the Windows screen normally. A reboot would then result in a normal POST and the LED turns off.I updated the ASUS APEX Z790 with the latest BIOS 2503 with 0x129 microcode, and I get random black screens while posting at any settings. It also crashes with RAM at settings that were stable on older BIOS versions.
