PSU AT to ATX conversion...
woscarr
Ottawa, Canada
Can it be done ?
I have about 4, 200w PSU's but they all have AT type connectors. I have a motherboard that needs a ATX type connection to the psu. Can I make/buy some sort of adapter to do this ?
I want it to run my ol' AMD450/AopenAX59pro Combo so 200w psu will do fine.
I would rather make one myself than buy one because I would imagine they would be 10 or 15 bucks, and I can pick up a chepo PSU for about 25 & tax CDN funds.
Anyone out there that could give me a little direction in completing this task.
Thanks
Wayne
<<<alpha sig test>>>
My main Rig:
Duron800@992. L7 1.85v mod 8x124Mhz. FBS.
ECS K7S5A. Mobo30c/CPU 40c idle 45c max.
Cidicom 5E34B3-HH cpu cooler for AMD & Thermal grease.
250w PSU (noname) 3.3&5v=100/150wmax@14a/15a.
Georce2 MX 400 32meg XP detonator 28.32 drvs.
SoundBlaster Live Value 1024.
Aopen 8x8x32 CDR/CDWR.
Fujitsu 20gig 5500rpm H/D.
2 3" 12v case fans running@7v mod, H/D cooler/twin fans, Geforce HSF.
CH Flight Sim Yoke & Pro Peddles.
Windows 98se/Windows 2000pro dual boot system.
<<<alpha sig test complete>>>
I really don't know if it can be done, or if it CAN be done...if it would be wise. Hoot will read this and he'll be able to tell you. I don't think there is anything he doesn't know about PSUs. :)
If it was even possible, it really wouldn't be worth the time and effort to match up the signal cables to make an AT work inan ATX box.
