Psu compatible for my gto2
moneyownzall
Well I've finally decided on getting a x800gt02. And im just making sure if my l&c 450w psu will be able to work with that card?
Sorry, but L&C is Deer... about the worst one can get. It should be replaced ASAP whether it initially works or not. Not sure what else you're running, but if you're on a budget, the Fortron/Sparkle AX450-PN, AX400-PN, ATX400-PA, or ATX350-PA will do the trick and all will outpower the L&C.
i have found worse then deer myself. infact, my allied PSU is still working good. however, i hate Powmax and MGE power supplys with a passion. (unless they are deer on the inside) :)
