PSU For RTX 4090
Poorman65
My PSU died on me so I need to replace it now. I currently have a Corsair CX600 driving a PC I built back in 2017 with a GTX 1070 TI GPU. My plan is to rebuild early next year with an RTX 4090 GPU. I am not a big overclocker.
I'm not sure what my best options are for under $200. I see an "ASUS ROG STRIX 850W Gold PSU (‎ROG-STRIX-850G)" on Amazon right now for $115, which has a list price of $180.
Is that a good choice or is there something else I should be looking at? I did see some comments about people waiting for ATX-3. Should I get something cheap now to tide me over until the new standard hits?
Appreciate any help!!!
Woomack
Benching Team Leader
850W Gold 80+ units should be good enough. I don't know who is the OEM for ASUS PSUs, but every known brand Gold/Platinum 80+ is good nowadays.
I know that RTX4090 works on quality/high-efficiency 750W PSUs too, and EarthDog was using 850W in his reviews.
Most, if not all RTX4080/4090 cards have a 3x8pin to 12/16 PCIe 5.0 adapter included. It's recommended to plug every 8-pin into a separate cable (if a cable has 2x8-pin, then use only one). So the best would be a PSU with 3x single 8-pin connectors or 3x double 8-pin (6x 8-pin in total). The mentioned ASUS Strix PSU has 6x 8-pin on 3 cables, so will be just right.
Tyerker
I would second the recommendation to have each 8-Pin for the GPU on a separate line from the PSU.
80+ Gold or Platinum from brands like Corsair, EVGA, or Seasonic would be my recommendation. If I have a $2,000 GPU, I'm not trying to save $30-50 on the PSU. So I would be very selective with my manufacturers.
850W should likely be OK with your current CPU, but if you go DDR5 you might be bordering on 1000W territory. A fully boosted/overclocked 13th Gen i9 + 4090 could potentially pull closer to 900W (I'm seeing articles citing 250W+ on the i9, as well as 4090 hitting almost 600W in Furmark), so the headroom of a 1000W unit might not be a bad idea.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
My 850W PSU with 13900K and 4090 are livin' the life together. I upgraded from 750W. ;)
Granted I don't do stuff like force feed a power virus (furmark) to my GPU and run a stress test against my CPU at the same time... lol
