PSU Hole Dimensions PLEASE!!!
Gromet
Hello all, Doing some designs for a new case this weekend but don't have a power supply to get the dimensions and hole numbers from, Can Someone anyone please give me the dimensions for
1. The overall PSU (Like a 350W Antec)
2. The Four Screwhole Locations and dimensions
3. The Size hole I would need to cut to give clearance to the fan, Power Cord and voltage switch...
Thank you So much
Even a link to a spec would do if it had dimensions...
Thanks again.
Gromet
Gromet
I'm building a 100% custom case. Cube design, easy removeable MOBO Tray, Two 3.5" Drives, Four 5 3/4" Drives, two hard drives, at least four 80mm fans (2-intake 2-Output), plus PSU. All Alluminum, Window in top, Compact yet Holds everything, and looks WAY COOL...
Gromet
Gromet
Don't have pics yet, spent like the entire weekend so far putting it all to paper. As far as how it is getting made, It is going to be 2 or 3mm Aluminum havent decided yet, and will be laser / Water Jet Cut, Welded and polished in a machine shop. Still contemplating color Anodizing the Aluminum, not sure yet.
What else would you like to know?
Dissolved
OC California
sounds good...
glad to see a real modder.. alot of ppl crap out and buy pre-made stuff :)
Gromet
Gromet
No, I'm absolutley going all the way with this, I am having one produced in the next week or so, than will be going into production with these units, if I can see a demand for them, we will have to see the reaction to the pictures...
Dissolved
OC California
thats cool.. if you can make better cases then Lain Li cheaper, then ull probly make alot of money
WyrmMaster
I'm a little teapot Senior
Montana, USA
Sounds about like the one that was posted in the forums and on the front page a couple weeks ago. Thats ok, im working on making one like that myself. Currently working on the Auto CAD drawings, in 3D:D
