fuzzba11 said:
Definitely sounds like the video card is your problem, since it will run fine at 1250. I would send the card back for a replacement, a power supply would give you errors across the board, not just with graphics.
I just installed Rivatuner and my bios reports:
$ffffffffff ----------------------------------------------------------------
$ffffffffff NVIDIA VGA BIOS information
$1100000000 Title : GeForce 7800 GTX VGA BIOS
$1100000002 Version : 5.70.02.11.25
$1100000100 BIT version : 1.00
$1100000200 Core clock : 275MHz
$1100000201 Memory clock : 1200MHz
$1100010000 Performance level 0 : 275MHz/650MHz/1.20V/100%
$1100010001 Performance level 1 : 415(+35)MHz/650MHz/1.40V/100%
$1100010002 Performance level 2 : 460(+40)MHz/650MHz/1.40V/100%
$1100020000 VID bitmask : 00000011b
$1100020100 Voltage level 0 : 1.20V, VID 00000000b
$1100020101 Voltage level 1 : 1.30V, VID 00000010b
$1100020102 Voltage level 2 : 1.40V, VID 00000001b
$1100030001 Core thermal compensation : 8°C
$1100030002 Core thermal threshold : 115°C
$1100030003 Ambient thermal threshold : 110°C
$1100030004 Thermal diode gain : 0.792°C
$1100030005 Thermal diode offset : 23.060°C
is there anything wrong with the report?
