I will be putting this build together this week when the GPU arrives, last piece missing:
https://pcpartpicker.com/user/Evil-MOBO/saved/#view=kj9gXL
I have an EVGA 1000W T2 on hand. I know it's overkill for this build, but it was not intended for this build, things changed. So should I dump it and get a 650W G2 or just use it because I have it? Not sure what negative affects if any there would be using that much over head on the PSU.
Thanks
Thanks
