PSU Question
phpguru
California
Forgive me for my lack of basic PSU fundamentals but..
If my computer only needs 350w and i have a 480w power supply.. will it only use 350w and save energy? Would it be the same as having a 350w instead of a 480w?
I'm 90% sure it saves energy completely to act like a 350w.
phpguru
the hammer
phpguru
It will just supply 350watts. It isn't gonna "dump" any extra wattage not being used. IMO, higher rated PSU's tend to run a little more efficient because they don't have to dump alot of heat because they are running a small load.
Hammer
phpguru
phpguru
California
So a high wattage power supply running a low load will create a high amount of heat?
phpguru
dustybyrd
Senior Member
San Francisco, CA
phpguru
no, a high wattage supply is more efficient, thus creating less heat as waste, while supplying the same amout of energy required by the system...
phpguru
phpguru
California
Awesome responses. This is why I love these forums :)
Just bought a 480w power supply for my new p4 to leave room for OC and expansion. Thanks a lot guys.
phpguru
