PSU sleeving guide
Just started on my sleeving yesterday and found tonight when doing a nother bundle that I marked my black com wire but not sure if I marked the right one or not is there any way to tell on com wire from the other. (black wires) AHHHhhh! hope I didn't screw up!!:(
*EDIT* by the way Very informative guide man! Good job!!:)
Thanks guys :D
The black wires that were attached to my pcb (printed circuit board) were all soldered together at the same spot so it didn't matter which one was placed back in the plug.
If you check yours I'd think it was basically the same .
Thank you very much, I sincerly appreciate it.
One day I may just have to follow through and sleeve my psu.
Nice guide, thanks.
I recently got Flexo tubing, but opted for the normal (non UV) blue kind. I also opted for blue heatshrink.
Then I realized that in my PSU array, I'm cutting out most of the unnecessary cabling, so it'll be a short mod ;). The cables will be soldered directly to a "power bus", which is made up of 6 gauge copper wiring, which I'm covering with split rigid sleeving.
