- Jun 20, 2002
- Winnipeg
I have read many threads where the poster claims that putting the rad in between the pump and block improves performance by 1 or 2c. The idea being that the pump heat is removed before the water hits the block.
From what I read elsewhere, a 100watt load adds less than .5c to a 100gph flow. This means that a 30 watt pump will add less than .2c to the system. Since only about 50% or less heat is transfered at the pump, with the rest transfered throughout the system, the actual temp rise between the pump and block should be around .05c . A 10 watt pump sould be a third of that.
So the question is, is there something that I'm missing that can account for the larger improvement that people are seeing
EDIT: changed 100gpm to 100gph.
