Hello all,
New member here at overclockers. I'm just completing a new build and am a first time custom liquid cooler. I build a Desk PC, so I decided since I was doing all this extra work to build my PC into a desk, I would go the extra mile with a custom water loop.
So what's happening is that when I boot the PC, while it's posting and such, I can visibly see the pump moving water throughout the loop - great!. Once I load into windows the pump just seems to shut off.
I have an EK-Res pwm 140 pump/res combo, using an EK supremacy block on my CPU, and a PE360 Radiator with 6 fans in push/pull config.
Flow control Res > pump > block > Rad > Res.
The pump is powered through a 4 pin Molex(only 2 wires) connection on my Power Supply and a pwm plugged into my Mobo header.
At first I thought maybe the motherboard was not running the pump because temps were low enough, but I running CoreTemp, I'm sitting around 70 C idling, and it will max under light loads.
I guess I'm at a loss as to why it runs during boot, but stops when windows loads. Looking for any help you guys can offer.
Thanks!
P.S. I'm stepping out for lunch, may take a little while to respond to any questions about my build.
Thanks!
