- Mar 26, 2002
- San Francisco
OK, I'm building a roughly four foot bong setup. It's gonna run a CPU and GPU block in series. It's gonna be setup res/bong->pump->CPU->GPU->bong showerhead.
The waterblocks are the new revised CPUFX Z4 and CPUFX GeForce3 block. The whole setup is 1/2".
Now I need to get a pump, I already researched and set on the Danner Mag Drive series since they have a good high head. I originally chose the Danner 5 since at 4' it pumps 310 GPH. Now, that's unobstructed and under controlled conditions, so in reality I'll probably be looking at ~200 GPH. The next step up is the Danner 7 which does 480 at 4'. Drop that down with the resistance of the system and whatnot and you got at least 350 GPH.
Those figures are all guesstimates but whatever.
Now I need some advice, which one? The price difference is $3 so that's not an issue, I just don't want to overkill it with the Danner 7 (700 GPH at 0' head!).
Thanks!
--Illah
Thanks!
Code:
Pump Specs:
Head Feet 0 2 4 6 8 10 Max ht Watts
Mag Drive #3 Flow (gph) 350 325 270 177 77 20 10'
Mag Drive #5 Flow (gph) 500 410 310 180 75 10 10' 45
Mag Drive #7 Flow (gph) 700 550 480 400 300 120 13' 65
--Illah
