gamestoned
- Jul 23, 2015
- Dubai
Hey all,
Finally waited for Skylake to come & decided that Haswell-E is the way to go after seeing no real gain in 6700k line. So below is the build that I've finalized & buying all my components from Dubai (UAE). It's expensive to buy everything together so I want to get your thoughts on the below config & break it up on parts & purchase my next 3 months.
CPU Intel Core i7-5930K Processor (15M Cache, up to 3.70 GHz)
Cooler Corsair H110i GTX Extreme Performance Liquid CPU Cooler
Mobo Asus RAMPAGE V EXTREME/U3.1 LGA 2011-v3 Intel X99
Mem Corsair Vengeance LPX 16GB (2x8GB) DDR4 2666MHz - Black
GPU ASUS GeForce GTX 980 Ti STRIX 6GB GTX 980 TI-6Gd5
SSD Samsung 850 Pro 256GB x 2units (Raid 0)
HDD WD Black 4TB SATA 6 Gb/s, 7200 RPM, 64MB Cache
Case Corsair Vengeance C70 Mid-Tower Gaming Case - Military Green
PSU Corsair AX1200i 80+ Platinum Fully-Modular ATX Power Supply
KB Corsair Vengeance K70 RGB Mechanical - Cherry MX Red
MS Asus ROG Gladius Wired Optical Mouse
DISP Asus ROG SWIFT PG278Q 144hz 27" Monitor
Look forward to hearing from people using similar systems or knowledge in the same. I might buy a second 980Ti Strix 6-8months from now when the price is down.
Thanks in advance
Paul
Budget: $4000
Main uses of intended build: Pure Gaming/Overclocking
Parts required: Mentioned Above
Previous build information (list details of parts):
Monitor resolution: 1440p
Storage requirements: 4tb + Raid 0 256 GB
Will you be overclocking: yes
Thanks in advance
Paul
Budget: $4000
