- May 15, 2005
- French Mountains
hi'
as you can see on my sig, I have a prescott OC @ 3.8.
now, I see that the voltage isn't this stable, so I turn it to 1.5v,
base is 1.42v.
I'm on air, I can push the fsb to 250 with a ram 1:1.
just afraid of high temp.(over 60°c on load)
the question is how far can I go riskless with the voltage of the cpu to reach this 4ghz?
will it affect the agp and pci if they are left to default settings in bios?
since I put 1.5v the temp didn't change.
and the system is a bit faster too ... cpu works easier.
max under prime, everest looking ... 49°c
anyone has an advice?
i686
ps; will change for a core2duo, but it's not for right now ..
base is 1.42v.
i686
